GCC __attribute___((aligned)) not aligning as expected
bitto
Post by bitto »
I'm facing an alignment problem with problem with gcc 7 (the one contained in ChibiStudio preview 21) compiling code for ST NUCLEO-F466RE board.
In fact with this code:
static GUARDEDMEMORYPOOL_DECL(memoryPool, TELEGRAM_SIZE, sizeof (stkalign_t));
static telegram_t mpTelegramWa[TELEGRAM_POOL_SIZE] __attribute__((aligned(sizeof(stkalign_t))));
gcc produces an array of [font=Courier New]telegram_t[/font] structs aligned on a 4 byte boundary:
  • element #0 address is 0x20001850
  • element #1 address is 0x20001864
even if [font=Courier New]sizeof (stkalign_t)[/font] correctly resovles to 8.
What am I missing?
Alberto
Re: GCC __attribute___((aligned)) not aligning as expected
I think GCC aligns the base of the array, not each element of the array. You need to pad the size of your structure.
bitto
Post by bitto »
it makes sense.
Incidentally, is it necessary to align memory to 8 byte boundaries on STM32, or could 4 be sufficient, since it's a 32 bit machine?
Alberto
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
It is possible to define an alignment for a type; then if you have an array of that type they will be individually aligned.
https://gcc.gnu.org/onlinedocs/gcc-3.3/ ... butes.html
bitto wrote:Incidentally, is it necessary to align memory to 8 byte boundaries on STM32, or could 4 be sufficient, since it's a 32 bit machine?
4 is sufficient, only for stacks ARM EABI mandates an 8 bytes alignment (4 works but they decided to align to 8).
Afanador
Post by Afanador »
What was the reason they went for 8 instead of 4, Giovanni?
I think forward compatibility with 64 bits bus architectures, aligned accesses are faster.
