For our application (STM32f042) we want to disable the idle thread to save flash space.
When we disable it via chconf.h, our firmware hangs (never starts up).
Our main() implements an infinite loop, like so:
while (true) {
chThdSleepMilliseconds(MAIN_THREAD_CHECK_INTERVAL_MS); //1000 ms
stats_check += MAIN_THREAD_CHECK_INTERVAL_MS;
if (stats_check > MAIN_THREAD_SLEEP_NORMAL_MS) {
/* TODO re-enable this when we have safe I2C / CAN simultaneous operation */
broadcast_stats();
stats_check = 0;
check_system_state();
return 0;
What else can we check / set?
Firmware hangs when idle thread is disabled
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: Firmware hangs when idle thread is disabled
If you disable the idle thread then the main() becomes the idle thread, you cannot call any function that changes the thread state from there like that chThdSleepMilliseconds().
If you need delays there then you can implement a polled delay on the system time counter.
Thank you. I assume you mean allow the thread to run at maximum speed, since it is now the idle thread and will run at a lower priority than other threads.
Will the idle thread get starved if other threads never sleep or block?
- Contact:
Threads not releasing CPU (not sleeping) block lower priority threads.
The general rule is: the thread in execution is always the ready one with highest priority.
So, I changed the main() loop to a simple infinite loop and the firmware still hangs.
What should the main() implement besides a simple infinite loop?
- Contact:
Just a loop, I just tried this:
Enable assertions, checks and state checker in chconf.h and see if something is caught. Make sure you don't have some other state-changing code in the main.
int main(void) {
* System initializations.
* RTOS is active.
* Activates the serial driver 3 using the driver default configuration.
sdStart(&LPSD1, NULL);
* Creates the example thread.
chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO + 1, Thread1, NULL);
* Idle loop.
while (true) {
Users browsing this forum: Bing [Bot] and 5 guests
