wspiReceive called twice, no cleared NDTR register Topic is solved
error414
Has thanked: 3 times
Postby error414 » Sun Feb 28, 2021 7:04 pm
I play with WSPI and I noticed weird issue. If I call twice wspiReceive(), then NDRT register for DMA is not cleared.
Simple code for test:
#include "ch.h"
#include "hal.h"
int main(void) {
   wspiStart(&WSPID1, &config);
   /* NCSS */
   palSetPadMode(GPIOB, 6, PAL_MODE_ALTERNATE(10) | PAL_STM32_OSPEED_HIGHEST);
   /* SCK */
   palSetPadMode(GPIOF, 10, PAL_MODE_ALTERNATE(9) | PAL_STM32_OSPEED_HIGHEST);
   /* IO0 */
   palSetPadMode(GPIOF, 8, PAL_MODE_ALTERNATE(10) | PAL_STM32_OSPEED_HIGHEST);
   /* IO1 */
   palSetPadMode(GPIOF, 9, PAL_MODE_ALTERNATE(10) | PAL_STM32_OSPEED_HIGHEST);
   wspi_command_t mode;
   static uint8_t buffer1[512];
   static uint8_t buffer2[512];
   static uint8_t buffer3[512];
   mode.cmd   = 0x9f;
   mode.cfg   = (WSPI_CFG_CMD_MODE_ONE_LINE       | \
                 WSPI_CFG_ADDR_MODE_NONE          | \
                 WSPI_CFG_ALT_MODE_NONE           | \
                 WSPI_CFG_DATA_MODE_ONE_LINE       | \
                 WSPI_CFG_CMD_SIZE_8              | \
                 WSPI_CFG_ADDR_SIZE_24);
   mode.addr  = 0U;
   mode.alt   = 0U;
   mode.dummy = 0U;
   wspiReceive(&WSPID1, &mode, 3, buffer1);
   //ends in infinity while wspi_lld_serve_interrupt   "while (dmaStreamGetTransactionSize(wspip->dma) > 0U)"
   wspiReceive(&WSPID1, &mode, 3, buffer2);
   wspiReceive(&WSPID1, &mode, 3, buffer3);
while (true) {
   chThdSleepMilliseconds(1000);
Second calling of " wspiReceive(&WSPID1, &mode, 3, buffer2);" ends in infinity "while" because NDTR is not cleared, I checked communication in QSPI pin and all what should be send, were send.
Infinity while:
static void wspi_lld_serve_interrupt(WSPIDriver *wspip) {
  /* Portable WSPI ISR code defined in the high level driver, note, it is
     a macro.*/
  _wspi_isr_code(wspip);
  /* Stop everything, we need to give DMA enough time to complete the ongoing
     operation. Race condition hidden here.*/
  while (dmaStreamGetTransactionSize(wspip->dma) > 0U)  <-------------------------
  /* Handling of errata: Extra data written in the FIFO at the end of a
     read transfer.*/
  if (wspip->state == WSPI_RECEIVE) {
    while ((wspip->qspi->SR & QUADSPI_SR_BUSY) != 0U) {
      (void) wspip->qspi->DR;
Does not metter whether memory is connected or not, in both case same behavior. If memory is connected then firts calling "wspiReceive" fills buffer1 with propper data, so communication with memory works, at least for first "wspiReceive" calling.
My mcuconf.h
https://pastebin.com/GXneeyy7
* WSPI driver system settings.
#define STM32_WSPI_USE_QUADSPI1 TRUE
#define STM32_WSPI_QUADSPI1_DMA_STREAM STM32_DMA_STREAM_ID(2, 2) // stream (2, 7) = the same issue
#define STM32_WSPI_QUADSPI1_PRESCALER_VALUE 255
* Latest CHibiOs from github
* STM32F767Zi nucleo 144
Has thanked: 1076 times
Been thanked: 922 times
Re: wspiReceive called twice, no cleared NDTR register
Postby Giovanni » Sun Feb 28, 2021 7:24 pm
Moving in bug reports, I will give it a try probably tomorrow.
error414
Postby error414 » Tue Mar 02, 2021 12:16 pm
Small progress.
It started to work when I added "dmaStreamClearInterrupt(wspip->dma);". I'm not sure whether it's right solution, but it works
--- a/ChibiOS/os/hal/ports/STM32/LLD/QUADSPIv1/hal_wspi_lld.c   (revision 2bf5987875f11e02acc4f20eda412fabe7f6dafc)
+++ b/ChibiOS/os/hal/ports/STM32/LLD/QUADSPIv1/hal_wspi_lld.c   (date 1614683492813)
@@ -299,6 +299,7 @@
 void wspi_lld_receive(WSPIDriver *wspip, const wspi_command_t *cmdp,
                       size_t n, uint8_t *rxbuf) {
+  dmaStreamClearInterrupt(wspip->dma);
   dmaStreamSetMemory0(wspip->dma, rxbuf);
   dmaStreamSetTransactionSize(wspip->dma, n);
   dmaStreamSetMode(wspip->dma, wspip->dmamode | STM32_DMA_CR_DIR_P2M);
Postby Giovanni » Tue Mar 02, 2021 1:10 pm
Thanks, to be verified if it is an effect of the problem or the cause.
FXCoder
Has thanked: 180 times
Been thanked: 130 times
Postby FXCoder » Tue Mar 02, 2021 11:00 pm
I was doing some work with QSPI last year which had to be shelved due to other priorities.
Getting back on to that project soon though.
I did make some minor changes to QUADSPIv1 which were not extensively tested and there is likely more to be done...
Bob
Index: hal_wspi_lld.c
--- hal_wspi_lld.c   (revision 14056)
+++ hal_wspi_lld.c   (working copy)
@@ -68,7 +68,6 @@
 static void wspi_lld_serve_dma_interrupt(WSPIDriver *wspip, uint32_t flags) {
-  (void)wspip;
   (void)flags;
   /* DMA errors handling.*/
@@ -77,6 +76,7 @@
     STM32_WSPI_DMA_ERROR_HOOK(wspip);
@@ -86,10 +86,6 @@
-  /* Portable WSPI ISR code defined in the high level driver, note, it is
-     a macro.*/
-  _wspi_isr_code(wspip);
@@ -102,6 +98,10 @@
+  /* Portable WSPI ISR code defined in the high level driver, note, it is
+     a macro.*/
+  _wspi_isr_code(wspip);
error414
Postby error414 » Thu Mar 04, 2021 12:15 pm
Thank you very much for comment FXCoder. Unfortunately the patch does't work me because "wspi_lld_serve_dma_interrupt" is not never called. Flags for enable DMA interupt are set to 0x0; There are enabled only flags for DMA error interrupts.
I can post all values from registers if needed.
FXCoder
Postby FXCoder » Fri Mar 05, 2021 12:47 am
Interesting that neither TCIE or HTIE are enabled yet there would seem to be a lingering ISR or other status blocking the next operation.
Inspecting the DMA ISR after the first receive could give a clue.
Bob
Postby Giovanni » Fri Mar 05, 2021 8:17 am
FXCoder wrote:Hi,
This is exactly what I want to do as soon I have some time for this, the 1st operation leaves the DMA and/or QSPI in an unfinished state probably. It is possible this is specific to the command format used, I have not seen problems using the existing flash infrastructure.
error414
Postby error414 » Fri Mar 05, 2021 3:27 pm
I'm so sorry for screenshots, it's not possible to copy whole register list :(
Screenshots are captured after first call "wspiReceive(&WSPID1, &mode, 3, buffer1);"
(two screenshots for DMA2, one for QSPI)
BTW: I use DMA2 Channel2
Postby Giovanni » Sun Mar 07, 2021 9:10 am
I have been able to reproduce the problem. The root cause is that the DMA interrupt is not enabled so the DMA ISR is not invoked in the DMA driver, flags are cleared there.
This is the fix I committed on trunk, apparently it works, could you confirm? I will back-port this to stable branches after confirmation.
     a macro.*/
  /* Clearing DMA interrupts here because the DMA ISR is not called on
     transfer complete.*/
     read transfer.*/
Traced as bug #1147.
Return to “Bug Reports”
Users browsing this forum: No registered users and 8 guests
