ChibiStudio
Stable and Unstable release events. This forum is NOT for support.
Has thanked: 1146 times
Been thanked: 960 times
Re: ChibiStudio
Postby Giovanni » Mon May 11, 2020 9:07 am
ChibiStudio for Linux 2020-05 has been released:
https://osdn.net/projects/chibios/releases/
Note that it is an experiment using the latest Eclipse and updated debug plugins, please report any problem you may have.
*** 2020-05 ***
- Updated to Eclipse 2020-03.
- Updated ChibiOS branches.
- Updated OpenOCD for STM32G4 support.
- Updated plugins.
- Included 19.x, 20.x and latest trunk.
The above guide posted by Rocco Marco is also valid for the Linux version. Note that this ChibiStudio version is designed to be located in /home/chibios/ChibiStudio, placing it to a different user/location requires editing of paths in workspaces and re-import of projects.
This version is also available into a full Linux Mint VM, no need to edit anything: user: chibios, pass: chibios. You can export ChibiStudio from the VM after trying it.
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Re: ChibiStudio
Postby RoccoMarco » Sun Jul 11, 2021 2:38 pm
ChibiStudio 2021-07 Release Candidate 1 for Windows has been released:
Note that a subsequent release will be prepared right after the release of ChibiOS 21.6.1.
*** ChibiStudio 2021-07 RC ***
- Updated Eclipse to 2021-06
- Updated all the Eclipse plugin
- Updated trunk code to revision 14595.
- Added ChibiOS 21.6.0.
- Updated chibios203 to ChibiOS 20.3.3.
Please report any issue you may find in the ChibiStudio subforum
RoccoMarco
Re: ChibiStudio
Postby RoccoMarco » Thu Aug 19, 2021 9:25 am
ChibiStudio 2021-07 Release Candidate 2 for Windows has been released:
*** ChibiStudio 2021-07 RC2 ***
- Updated trunk code to revision 14665.
- Added fmmp to the tools
- Added OpenJDK 11 to the tools
- Reviewed start-up batch files
- Minor workspace configurations adjustments
- Updated all the Eclipse plugin.
- Updated msys1 to msys2
- Updated Open On-Chip Debugger to 0.11.0 (2021-07-24-12:57).
- Fixed issue with ChibiOS Plugin
RoccoMarco
Re: ChibiStudio
Postby RoccoMarco » Thu Aug 19, 2021 3:46 pm
ChibiStudio 2021-07 Release Candidate 3 for Windows has been released:
*** ChibiStudio 2021-07 RC3 ***
- Updated trunk code to revision 14678.
- Updated compiler to gcc-arm-none-eabi-10.3-2021.07, alternate
  version is the old gcc-arm-none-eabi-9.2-2019-q4.
- Added OpenJDK 15 to the tools
- Updated start-up batch files
- Fixed issue with ChibiOS plugin.3.3.
I am uploading the file right now and it would be available any moment
RoccoMarco
Re: ChibiStudio
Postby RoccoMarco » Mon Jan 03, 2022 3:51 pm
ChibiStudio 2022-01 for Windows has been released:
*** ChibiStudio 2022-01 ***
- Added ChibiOS 21.11.1.
- Updated chibios203 to ChibiOS 20.3.4.
Re: ChibiStudio
Postby Giovanni » Sun Feb 12, 2023 10:48 am
ChibiStudio for Linux 2023-02 has been released:
https://sourceforge.net/projects/chibio ... o%20Linux/
Please report any problem you may have.
*** ChibiStudio Linux 2023-02 ***
- Updated to Eclipse 2022-12.
- Updated compilers to 10.3.1q4 and 11.3.1q3.
- Updated OpenOCD.
- Added PlantUML to Eclipse.
Note that the toolchain is meant to be used by an user "chibios" and must be installed under:
/home/chibios/Projects/ChibiStudio
It is possible to install under a different patch by Eclipse workspaces need to be repopulated and the workspace variable CHIBIOS adjusted accordingly.
A Linux VM with ChibiStudio pre-installed is available here: https://sourceforge.net/projects/chibio ... ibiStudio/
User and password are "chibios".
RoccoMarco
Re: ChibiStudio
Postby RoccoMarco » Tue Feb 28, 2023 3:18 pm
ChibiStudio for Windows 2023-02 has been released:
https://sourceforge.net/projects/chibio ... 2023-02.7z
Changelog
*** ChibiStudio Windows 2023-02 ***
- Updated Eclipse to 2022-12
- Updated trunk code to revision 16117.
- Updated compiler to gcc-arm-none-eabi-11.3-2022.08, alternate
  version is the old gcc-arm-none-eabi-10.3-2021.10.
- Added Plant UML
- Updated to ChibiOS 21.11.3.
- Removed to ChibiOS 20.3.x.
- Updated PLAY Embedded demos.
Return to “Releases”
Users browsing this forum: No registered users and 106 guests
