Faulty inclusion check solution (Unresolved inclusion)
d1nuc0m
Postby d1nuc0m » Thu Sep 02, 2021 10:17 am
Hello!
I am using ChibiStudio 2020-04 on Windows 10, and I've had problems with library inclusion check.
If I include a "standard" library (for example #include "string.h"), the project compiles & works, but ChibiStudio gives a warning about "Unresolved inclusion". I know that warnings can be ignored, but it is inconvenient having to distinguish a wrong warning from a real one.
I have found the reasons, so I would like to suggest a workaround/solution:
  • A part of the issue is due to Eclipse on a non-English system like mine. The solution is set the following environment variables in Preferences - C/C++ - Build - Environment. LANG = en_US, LANGUAGE = en_US, LC_ALL = en_US.UTF-8. These should be set to replace native environment ones. Reference: (1), (2), (3).
  • Then, as of topic 1759, the standard header paths (like C:\ChibiStudio\tools\GNU Tools ARM Embedded\9.0 2019q4\arm-none-eabi\include) should be included to the project (Properties - C/C++ General - Paths and symbols or Preprocessor Include Paths, Macros etc.). Maybe these folders could be already included in the default configurations.
Thank you :D
Has thanked: 1076 times
Been thanked: 922 times
Re: Faulty inclusion check solution (Unresolved inclusion)
Postby Giovanni » Thu Sep 02, 2021 10:28 am
Thanks for hints, very useful. The problem with putting paths in project settings is that not all users have same paths, some use customized Eclipse environments, some others use Linux or MacOS where paths are simply different.
d1nuc0m
Postby d1nuc0m » Thu Sep 02, 2021 12:53 pm
Giovanni wrote:Hi,
Thank you, is there a way to document this behavior of ChibiStudio (wiki, FAQ etc), so that if needed is an easy-to-find information?
Postby Giovanni » Thu Sep 02, 2021 1:06 pm
hi,
We don't have a documentation effort ongoing for ChibiStudio, it is just a collection of existing tools.
I could add a small article to the web site (it is a wiki basically).
Postby Giovanni » Thu Sep 02, 2021 7:36 pm
BTW those env variables could be set in the ChibiStudio launch batch files, so no need to change settings and projects.
We will add this to next release.
d1nuc0m
Postby d1nuc0m » Thu Sep 02, 2021 8:26 pm
Giovanni wrote:hi,
It's not a bad idea, to have this documented in a more "obvious" place than a random topic
Giovanni wrote:BTW those env variables could be set in the ChibiStudio launch batch files, so no need to change settings and projects.
Thank you! :D
Return to “ChibiStudio”
