STM32F7/H7 Fast Interrupts Topic is solved
mck1117
Been thanked: 9 times
Post by mck1117 »
Hello, I'm trying to use some "fast interrupts" as described here: https://www.chibios.org/dokuwiki/doku.p ... interrupts
The code looks roughly like this, with the defines in mcuconf.h like STM32_IRQ_EXTI0_PRIORITY set to 0 (or CORTEX_MAXIMUM_PRIORITY) so that they can preempt the kernel.
CH_FAST_IRQ_HANDLER(Vector58) {
   handleExtiIsr(0);
CH_FAST_IRQ_HANDLER(Vector5C) {
   handleExtiIsr(1);
CH_FAST_IRQ_HANDLER(Vector60) {
   handleExtiIsr(2);
This all works just fine on STM32F4. However, on F7 and H7, they use the new stm32_exti0.inc shared includes pattern, which performs an extra check that the interrupt priority is legal (ie, not higher pri than kernel), so I get a compilation error. Removing the check, the code does work properly, as it does on STM32F4.
What happened to using fast interrupts on F7/H7?
Re: STM32F7/H7 Fast Interrupts
Moving in bug reports, the check needs to be removed if the handler has been disabled using STM32_DISABLE_EXTIxxx_HANDLER.
mck1117
Post by mck1117 »
Thanks, that's what I figured to be the situation, but I wanted to confirm before making that change in rusEFI's fork of ChibiOS.
Disabled priority check on STM32 EXTI interrupts when the default ISR is disabled. This allows for fast interrupts.
