I want to generate code using STM32CubeMX and then perform tasks using Chibios' RT.
Put ST's HAL library into "ChibiOS-stable_21.11.x/ext", and then replace Chibios' hal with ST's HAL via Makefile in the Chibios demos example;
Or put "ChibiOS-stable_21.11.x/os/rt" in the project folder generated by STM32CubeMX.
Which one is a viable solution?
I'm trying it now and look forward to your reply.
Can chibios' RT and ST's HAL be used together?
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: Can chibios' RT and ST's HAL be used together?
RT can be used without our HAL no problems. I have never used the ST HAL but people have already used it with RT so it should be OK.
I recommend to use ChibiOS startup files and makefiles so I would include ST source code on top of a ChibiOS-like project, not all of it, just the parts you need adding drivers one at time.
It would also be possible to integrate RT into a CubeMX project but it is likely that ST startup files and makefiles don't do all things that are required so you would need to be extra careful.
Another note: you need to take care that all ISRs are written following the ChibiOS style (with prologue/epilogue macros)
BTW it is also possible to mix our HAL with specific drivers taken from ST HAL.
The best approach largely depends on what you are trying to achieve.
#HAL-OSAL files (optional).
include $(CHIBIOS)/os/hal/ports/STM32/STM32F4xx/platform.mk
include $(CHIBIOS)/os/hal/boards/ST_STM32F4_DISCOVERY/board.mk
include $(CHIBIOS)/os/hal/osal/rt-nil/osal.mk
When I comment out the above, why do I get an error?
Can you tell me how chibios distributes clocks? I wonder if it is possible to configure the clock with ST's HAL library?
For some reason, I wanted a pure CHIBIOS/RT+ST HAL, not CHIBIOS/HAL. Just use RT's threads, peripherals and interrupt configuration using ST's HAL, sorry for asking so many questions, I'm getting familiar with CHIBIOS.
- Contact:
If you remove HAL then the OS does nothing about initializing clocks, it is entirely up to you.
See the demo in /demos/various/RT-ARMCM4-GENERIC for an example of project without HAL, you may use it as a starting point.
