STM32F4 I2Cv1 doesn't see the aknowledge
asiemasz
Postby asiemasz » Fri Mar 24, 2023 4:08 pm
I'm trying to communicate with vl53l0x through the I2C interface. I checked both on an oscilloscope and logic analyzer and signals look good, but the software returns a not acknowledged status. I've seen some other topics about i2c issues on STM32F4 here and added pullup (4k7) to SDA and SCL lines, however, nothing is changing. I checked both fast and standard I2C modes.
While using STMCube and HAL both reading and writing to the device work (with the same pins configuration).
Pins are configurated with macros PAL_MODE_ALTERNATE(4), PAL_STM32_OSPEED_HIGHEST, PAL_STM32_OSPEED_HIGHEST and PAL_MODE_OUTPUT_OPENDRAIN. Any hints?
Has thanked: 1146 times
Been thanked: 960 times
Re: STM32F4 I2Cv1 doesn't see the aknowledge
Postby Giovanni » Fri Mar 24, 2023 4:51 pm
I would check the physical connection, it is very critical, how log are wires for example?
psyco
Been thanked: 11 times
Postby psyco » Fri Mar 24, 2023 10:46 pm
Try this:
PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN
asiemasz
Postby asiemasz » Sat Mar 25, 2023 2:27 pm
psyco wrote:Try this:
it is like that already.
Giovanni wrote:Hi,
Giovanni, wires are just regular short prototype connectors. As I said I tested the same configuration with STM32 Cube HAL and all works without errors.
Postby Giovanni » Sat Mar 25, 2023 3:05 pm
Are you using the correct address?
Note that in ChibiOS you need to pass the address field value without the RW bit, not the whole 1st byte value.
asiemasz
Postby asiemasz » Sun Mar 26, 2023 12:51 am
Giovanni wrote:Hi,
Yes, I also checked the signals from both chibios and Cube and they look the same - it has aknowledge.
Screenshot from the logic analyzer: https://ibb.co/3dKW6Wn
FXCoder
Has thanked: 186 times
Been thanked: 133 times
Postby FXCoder » Sun Mar 26, 2023 11:38 am
Is the I2C config something like this?
const I2CConfig _i2cMainCfg = {
    OPMODE_I2C,
    50000,
    STD_DUTY_CYCLE,
I know this configuration works on F413 with BME280 configured for I2C use.
(Should be using dot notation for member access but this is old code).
Bob
asiemasz
Postby asiemasz » Sun Mar 26, 2023 4:36 pm
FXCoder wrote:Hi,
    OPMODE_I2C,
    50000,
    STD_DUTY_CYCLE,
Bob
Yes, it looks the same for lower clock frequencies as well.
asiemasz
Postby asiemasz » Fri Mar 31, 2023 6:11 pm
Funny enough, I2C2 works with the same configuration.
Postby Giovanni » Fri Mar 31, 2023 6:24 pm
Strange, is it possible I2C1 pins are shorted or connected to something else on the board? defective device?
Unless it is a GPIO setting problem it should be an HW problem.
Return to “ChibiOS/HAL”
Users browsing this forum: No registered users and 81 guests
