openocd -rtos "chibios"
Tuxford
Has thanked: 4 times
Been thanked: 4 times
Post by Tuxford »
I downloaded latest ChibiStudio for Linux. My local openocd version 0.12.0.
Config options are next:
-f interface/stlink.cfg -f target/stm32f1x.cfg -c "$_TARGETNAME configure -rtos chibios"
But there is no success.
Warn : ChibiOS/RT memory signature claims to be bigger than expected. Assuming compatibility...
Info : Successfully loaded memory map of ChibiOS/RT target running version 7.0.4
Error: ChibiOS registry integrity check failed, double linked list violation
Info : Only showing current execution because of a broken ChibiOS thread registry.
What I missed?
Re: openocd -rtos "chibios"
OpenOCD support is not yet updated to the latest ChibiOS versions.
You may try the ChibiOS Debugger View in ChibiStudio, it provides even better functionality.
szekelyisz
Post by szekelyisz »
Giovanni wrote: Sun Feb 23, 2025 4:22 pm OpenOCD support is not yet updated to the latest ChibiOS versions.
Is there any chance this happening? I tried changing `ch` to `ch_system` in `src/rtos/chibios.c` but didn't do the trick alone. Here's what I get now:
[stm32f1x.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08000248 msp: 0x20000400
Error: Failed to read memory at 0x5555556d
Info : Padding image section 0 at 0x08000164 with 12 bytes
Error: ChibiOS registry integrity check failed, NULL pointer
Error: Failed to read memory at 0x20005018
It looks like `rlist` has moved quite a bit in ChibiOS 7.x due to the introduction of instances, so this might be a bigger change. Looking into it, but not sure I can get to the bottom of this soon.
Giovanni wrote: Sun Feb 23, 2025 4:22 pm You may try the ChibiOS Debugger View in ChibiStudio, it provides even better functionality.
Except that it doesn't provide the stack trace which makes debugging really difficult. Or am I missing something?
Thanks, Szabi
It is being addressed, starting from RT7 things changed quite a bit because it added multicore support and some data structures changed.
A repository will appear about this on my personal github or the chibios-upstream github organization.
It is here: https://github.com/gdisirio/openocd-chibios (branch chibios-rt-support)
The RTOS name is chibios-rt7 instead of chibios which is for legacy kernels.
I will try to upstream it when fully done.
