MIPS32 port
Re: MIPS32 port
For retrobsd it's fine to have such partitioning, but for chibios, which is completely executed in kernel mode, it does not make sense =/.
Re: MIPS32 port
I want to put some functions into RAM(like vectors, ISRs, and maybe some "user" functions).
Re: MIPS32 port
According to the spec by default all RAM is reserved for "kernel DATA". With manipulation of bus matrix configuration you can reserve some space for "kernel TEXT", but there are some limitation. The granularity of the segment is 2K and since register width is 16 bits you can allocate only up to 0xF800 bytes per segment. If I don't use user space there's some waste in case of 128KiB SRAM. And in fact I'm not sure that I really need so much program space.pito wrote:afaik you can allocate the whole ram for kernel..
Re: MIPS32 port
Serge from retrobsd is the MIPS guy, he may provide you with an advice if needed.. I've sent a message to him..
Re: MIPS32 port
Thanks Pito. But this is more PIC32 thing than MIPS-specific.
Anyway I did a small benchmark where all ISR are in SRAM and in fact this gives slight win only in timers tests. In other tests the results are significantly lower. I suppose that this is due to -mlong-calls.
I'm not a big expert of MIPS cores but seems like m4k has very simple branch predictor and it can't prefetch in advance if jump to register instruction is used(JR, JLR).
So this "execute from RAM" doesn't make any sense for me unless you put everything into SRAM.
Re: MIPS32 port
Dmytro wrote:but seems like m4k has very simple branch predictor and it can't prefetch in advance if jump to register instruction is used(JR, JLR).
..once upon a time there was a discusion at retrosite on missed delay slots when talking J, JR; enabled/disabled reorder mode, etc..
Re: MIPS32 port
due to the harvard arch and the flash caching, it often will be slower to execute out of RAM with a PIC32.
the bus has to switch between reading code and read/write memory.
It gets even worse with a real fast peripheral DMA since almost half of the RAM bandwidth can be allocated to DMA.
Best to execute out of flash since the two buses can be fetching simultaneously.
Re: MIPS32 port
rocketdawg wrote:due to the harvard arch and the flash caching, it often will be slower to execute out of RAM with a PIC32.
Yes, this makes sense!
