STM32f4 + Keil uVision and new project setup build errors
Re: STM32f4 + Keil uVision and new project setup build error
Sure, that sounds like a sane way to go.
ChibiStudio also features some custom plugins like to set the I/O pin modes etc. People here seem to love it.
Question, but do the included Keil demos (unmodified) work for you?
He said so in another post, yes:
The demo application compiles OK which is encouraging.
Tectu and Giovanni,
Thanks again for taking an interest..
For my part a more successful day's work really,
After much reading I installed ChibiStudio compiled the STM32F4407-Discovery demo project (13secs), just one warning:
I used the ST-Link Utility and ST-Link to program/verify and all runs, well I haven't checked the output yet but I have flashing LEDs galore...
I use one of these http://www.wvshare.com/product/Open407V-D-Standard.htm as a baseboard - excellent value and supports the Discovery board well. In this case the JTAG port is very convenient.
Next step is to monitor the test data output on USART2 and start to learn how to use the OS. I have a couple of HD44780 displays kicking about for which I see someone has generously donated a driver - that will be a starting point for practice.
Once again thanks to the generosity of folk who contribute there time and expertise ton forums like this to help those like me who are less knowledgable I have been able to make what to me is good progress - top stuff
Cheers,
Chris
main.c:167:1: warning: no return statement in function returning non-void [-Wreturn-type]
Cheers,
Chris
motley wrote:I have a couple of HD44780 displays kicking about for which I see someone has generously donated a driver
If you're talking about this one, there has been introduced a completely stand-alone module for driving that kind of displays.
In case of you got the GLCD together with the board you liked, there's also already an existing driver for that one.
And thanks for your nice words, I guess everyone here is giving his best
Joel,
The first one you mention was the one I saw but I like the look of the standalone module very much - co-owned by you I see
I'm not sure if the budget will run to a full graphic display but I have seen some cheaper ones about recently so maybe...
Cheers,
Chris
Cheers,
Chris
Should I know you from somewhere or did you found my name on the owners list?
You can get some very cheap TFT modules with touchscreen. For example, there are quite a few different SSD1289 driven 3.2", 320x240 touchscreen display modules for 16$ on ebay. 5" will cost you like 50$ and a 7" is around 75$.
Also, the TDISP module should work but I didn't try it out after the last contribution (I simply didn't found the time to get the hardware up again since I don't have a dedicated board for that). Please let me know if there are any issues.
That warning is known and accepted, it is present in most demos, the cause is that GCC complains about the following:
Since xxx is supposed to return "int" GCC complains even if the infinite loop obviously prevents the function from returning. The solution would be to write it like:
but in this case are the other compilers to complain, specifically Keil and IAR, because the "return 0" cannot be reached. Since GCC is minority I prefer to not put the "return" and accept the warning.
int xxx(void) {
while (1) {
int xxx(void) {
while (1) {
return 0;
That can be fixed:
Not sure if this is GCC only (but at least the syntax will be, I assume).
But I agree with you, better say with a warning which is absolutely 100% not critical instead of making compiler dependent code and other nasty stuff.
__attribute__((noreturn))Not sure if this is GCC only (but at least the syntax will be, I assume).
It is a non portable construct and I believe you can't apply it to non-void functions anyway.
