No rule to make target crt0
- RoccoMarco
- Has thanked: 83 times
- Been thanked: 67 times
Re: No rule to make target crt0
Sorry, I was referring to the type of STM32 board you are using... anyway I hope you have downloaded last preview version of Chibistudio otherwise you can download the preview 4 from here. Just unizip the archive and copy the folder Chibistudio in C:\ in order to have that main folder would be like this.
As Giovanni said you have to open chibistudio from the shortcut C:\Chibistudio\Chibi Studio.ink or from the batch file C:\Chibistudio\start.bat
When you open Chibistudio (to the left) you can see more projects for more platform, like this
These projects that you see, at first run, are located in C:\ChibiStudio\chibios\demos.
The easy way out is follow this steps:
1.copy one of the project for your board in folder C:\Chibios\workspace,
2.from chibistudio->file->import->next and in the field "Select root directory" browse the path of copy folder
3.in project explorer (left panel in chibistudio) right click on ChibiOS/RT STM32 demos->properties->working set content and select the folder that you copied in step
in order to see the imported project in the list.
4.make a modification probably at line 67 from "CHIBIOS = ../.." to "CHIBIOS = ../../chibios"
I have been playing around with settting up my stmf0-discovery board, and
in messing around with it got this same error.
From Project menu do a Clean...
Then from Windows Explorer, rename the: .dep folder to .dep_old ( or something... )
When you recompile it will rebuild everything.
I have had some odd problems here and there, and have found that this seems to solve
many of them.
Let us know if this helps
-John Scott
www.atl123.com
many of them.
-John Scott
www.atl123.com
