chThdSleepMilliseconds doesnt return
Legath
Re: chThdSleepMilliseconds doesnt return
Post by Legath »
Hi
I use both, linker script and startup, i disabled built-in toolchain startup.
I know about Makefile, but do not like this way.
If the Makefile works then it must be something in the project setup, cannot help there.
Legath
Post by Legath »
Hi
just for clarification, i have hang at 241 line in chcore_v7m.c
 asm volatile ("vpush   {s16-s31}" : : : "memory");
i will double check Makefile example.
Regards.
Careful, you are hitting code related to the FPU, if you define CORTEX_USE_FPU=TRUE in your project then you also have to give the appropriate options to the compiler (-mfloat-abi=softfp -mfpu=fpv4-sp-d16 -fsingle-precision-constant), please examine all the logic related to the FPU in the Makefile.
Legath
Post by Legath »
many thanks, after adding -fsingle-precision-constant all works.
[update]
now i have hang at the end of stm32_clock_init(void).
if i just run board all works.
Regards
