Page 2 of 2
Re: Need explanations about Floating Point Unit
Posted: Sun Feb 02, 2014 4:13 pm
I just compiled the IRQ_STORM_FPU demo for the F4 and it generates FPU instructions:
56 0000 06EE100A fmsr s12, r0
57 0004 06EE901A fmsr s13, r1
58 0008 00EE102A fmsr s0, r2
59 000c 00EE903A fmsr s1, r3
60 0010 36EE267A fadds s14, s12, s13
61 0014 70EE207A fadds s15, s0, s1
62 .loc 1 23 0
63 0018 27EE271A fmuls s2, s14, s15
64 001c 11EE100A fmrs r0, s2
Posted: Sun Feb 02, 2014 4:51 pm
by pito
It might be we simply link the math lib without recompiling it for FPU. I would be happy to see a difference in the trigonometric demo I posted - my naive understanding is the demo w/ FPU on shall be at least 2x faster compared to sw math
PS: I can see a diff when doing simple mult/div (8x), the -DUSE_FLOAT=TRUE in Makefile has no effect, the USE_FPU = yes does.
Now, how to recompile the math libs.. The time diff in above trigo test is 111 vs 114, so it seems the math libs are sw double.
The CMSIS-DSP includes arm_cortexM4lf_math.lib (Little endian and Floating Point Unit on Cortex-M4)
Posted: Sun Feb 02, 2014 6:58 pm
by pito
I've added the path to fpu libs libm.a
C:\ChibiStudio\tools\GNU Tools ARM Embedded\4.7 2013q2\arm-none-eabi\lib\armv7e-m\fpu
C:\ChibiStudio\tools\GNU Tools ARM Embedded\4.7 2013q2\arm-none-eabi\lib\armv7e-m\softfp
and changed:
q32= asinf(acosf(atanf(tanf(cosf(sinf(q32))))));
With
I get 31ms (vs 111ms) so ~3.5x speedup.. Good..
With
I get 57ms (vs 111ms) so ~2x speedup.. Not so good..
Posted: Sun Feb 02, 2014 7:21 pm
If this works then it would be a good idea to change defaults, I don't know if there are hidden problems however in using the hard compiled libraries.
Posted: Sun Feb 02, 2014 8:10 pm
by pito
As a first step I would try to link the original STM hard fpu libm.a if any - I would expect much better results as with the above gcc one.
Posted: Mon Feb 03, 2014 10:50 am
by pito
Nope, the hard does not work properly. It seems it just passes the argument through the function - see sinf (for example):
-mfloat-abi=hard:
sinf( 1 ) = 1.00000
sinf( 2 ) = 2.00000
sinf( 3 ) = 3.00000
sinf( 4 ) = 4.00000
sinf( 5 ) = 5.00000
sinf( 6 ) = 6.00000
sinf( 7 ) = 7.00000
sinf( 8 ) = 8.00000
sinf( 9 ) = 9.00000
sinf( 10 ) = 10.00000
-mfloat-abi=softfp:
sinf( 1 ) = 0.84147
sinf( 2 ) = 0.90929
sinf( 3 ) = 0.14112
sinf( 4 ) = -0.75680
sinf( 5 ) = -0.95892
sinf( 6 ) = -0.27941
sinf( 7 ) = 0.65698
sinf( 8 ) = 0.98935
sinf( 9 ) = 0.41211
sinf( 10 ) = -0.54402
Posted: Mon Feb 03, 2014 11:03 am
It could be matter of problems in the Makefile, are the options passed to both compiler and linker?
Posted: Mon Feb 03, 2014 11:52 am
by pito
Ok, it seems this is the fix:
In rules.mk:
MCFLAGS = -mcpu=$(MCU) -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
in Makefile:
# End of user defines
ifeq ($(USE_FPU),yes)
USE_OPT += -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
DDEFS += -DCORTEX_USE_FPU=TRUE
else
DDEFS += -DCORTEX_USE_FPU=FALSE
endif
Now the above test demo with
hard shows:
THIS IS THE START
Elapsed time 1000x : 9 millis
Elapsed time : 0.00899 millis
Result : 9.00001
THIS IS THE END
The same results with
softfp.Code: Select all
THIS IS THE START
Result : 9.00001
THIS IS THE END
The results with FPU off (in Makefile) and with the original rules.mk, single precision ( q32= asinf(acosf(atanf(tanf(cosf(sinf(q32)))))); ):
THIS IS THE START
Elapsed time 1000x : 59 millis
Elapsed time : 0.05900 millis
Result : 9.00001
THIS IS THE END
The results with FPU off (in Makefile) and with the original rules.mk, but double precision ( q32= asin(acos(atan(tan(cos(sin(q32)))))); ) :
THIS IS THE START
Elapsed time 1000x : 114 millis
Elapsed time : 0.11400 millis
Result : 9.00000
THIS IS THE END
So 9 ms against 114ms (13x faster than double precision), and 9ms against 59ms (6.5x faster than single precision) - unbelievable, there still must be an issue somewhere
