EXT Driver Crashing on STM32F4 Discovery
Graeme
Re: EXT Driver Crashing on STM32F4 Discovery
Post by Graeme »
Thanks for your help on this. Will dig a bit deeper.
However, on thing that I have seen is
#if CORTEX_SIMPLIFIED_PRIORITY
mov r3, #SCB_ICSR :AND: 0xFFFF
movt r3, #SCB_ICSR :SHR: 16
mov r2, #ICSR_PENDSVSET
str r2, [r3, #0]
cpsie i
waithere b waithere
#else
svc #0 /*This is the last line that gets executed and get sexecuted after exiting the EXT interrupt*/
What does CORTEX_SIMPLIFIED_PRIORITY do, and should I have it defined?
Thanks again for your help.
Graeme
It is defined in chcore_v7m.h and documented in the ARMCMx port document.
Graeme
Post by Graeme »
Project was set to 25MHz cru\ystal, but STM32F4 only has 8MHz crystal on board.
Changing this to 8MHz has stopped the crashing, but for some reason when pressing the pushbutton, I don't always get an interrupt.
Anyway, I will dig further
Regards
Graeme
You need to create specific board files AND settings in mcuconf.h when porting on new boards.
Graeme
Post by Graeme »
Hi Giovanni
Testhal\EXT\main.c test code was disabling the EXT every 5 seconds for 5 seconds. No wonder I was missing interrupts :)
All fixed now and all working
Thanks again
Graeme
