EXTI Driver
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Re: EXTI Driver
Post by Tabulous »
Giovanni wrote:This should mean that the front is detected after the call to extStart(), there is no interrupt pending at that point.
I dont understand what you mean ?
All i know is that if a pin is high when you call extStart and you have it set for both edges, you will get a callback, which to me is wrong, as there have never be any transisitions, the pin has only ever been high.
If a pin is configured to input and floating, and it is pulled high with an external resistor, thus before any code is running the pin is high. If you now go and call extStart and you have it set for both edges/Auto start, you will get a callback............ yet there has been no transisition
Re: EXTI Driver
I am out of ideas. Resetting the PR registers makes sure that transitions happened before that moment are discarded.
You may try to not autostart the channels.
Tabulous
Re: EXTI Driver
Post by Tabulous »
Giovanni wrote:I am out of ideas. Resetting the PR registers makes sure that transitions happened before that moment are discarded.
I've tried that too :( as soon as extChannelEnable is called, callback is triggered, the only why i can stop this is to configure the transition as EXT_CH_MODE_FALLING_EDGE's, but then i cant detect both edges...
Tabulous
Re: EXTI Driver
Post by Tabulous »
ive got a work around but its dirty, and dont really like doing it...... but putting a flag around the callbacks to mask them out, and then clear the mask on a Virtual timer.
i.e. Whist triggermask is FALSE ignore the callback.
static void extcb1(EXTDriver *extp, expchannel_t channel)
static VirtualTimer vt4;
    (void)extp;
    (void)channel;
    if(triggermask == FALSE)
        palClearPad(GPIOG, GPIOG_LED_STATUS_GRN);
        chSysLockFromIsr();
        if (chVTIsArmedI(&vt4))
            chVTResetI(&vt4);
        /* LED4 set to OFF after 200mS.*/
        chVTSetI(&vt4, MS2ST(200), led1off, NULL);
        chSysUnlockFromIsr();
Dont think one should have to do this but, its the only solution i got, and the only way i can think to mask out this issue.
Tabulous
Re: EXTI Driver
Post by Tabulous »
Just to update gone back to basics and got a bare main.c program with STLibs and this exerts the same issue, so cant be anything to do with Chibios.
What i can say is the F103 did not have this problem as ive just tested it.......Next stop Errata
Re: EXTI Driver
I already verified the errata, nothing apparently. I still think you are getting some kind of glitch on those inputs, you should verify with a scope, also try a stronger pullup.
Tabulous
Re: EXTI Driver
Post by Tabulous »
Giovanni wrote:I already verified the errata, nothing apparently. I still think you are getting some kind of glitch on those inputs, you should verify with a scope, also try a stronger pullup.
Same software on and same hardware input circuitry on an F103 works ok, so the only real difference is MCU, begin to this there is a silicon issue here.
If you have a discoveryF4 i would be interested to see what you get if you tie a pin to VCC, and set it up as EXTI, i think you'll see the same as me, i.e interrupt is triggered as soon as you setup the EXTI
Re: EXTI Driver
I have to wait for the weekend for a test.
theShed
Re: EXTI Driver
Post by theShed »
Can you try disabling irqs at the NVIC during startup of the ExtIrq and re-enable after clearing the PR.
Something like this:
    static msg_t ThreadIO(void *arg)
    Thread *p;
    struct iom *m;
        (void)arg;
        chRegSetThreadName("IO");
         * Activates the EXT driver.
        chThdSleepMilliseconds(1000); // wait for Hardware Driver to Settle
        extStart(&EXTD1, &extcfg);
        nvicDisableVector(EXTI0_IRQn);
        nvicDisableVector(EXTI2_IRQn);
        nvicDisableVector(EXTI3_IRQn);
        extChannelEnable(&EXTD1, 0);
        extChannelEnable(&EXTD1, 2);
        extChannelEnable(&EXTD1, 3);
        EXTI->PR = 0xFFFFFFFF;
        nvicEnableVector(EXTI0_IRQn,
                   CORTEX_PRIORITY_MASK(STM32_EXT_EXTI0_IRQ_PRIORITY));
        nvicEnableVector(EXTI2_IRQn,
                   CORTEX_PRIORITY_MASK(STM32_EXT_EXTI2_IRQ_PRIORITY));
        nvicEnableVector(EXTI3_IRQn,
                   CORTEX_PRIORITY_MASK(STM32_EXT_EXTI3_IRQ_PRIORITY));
        while(TRUE)
mike
Tabulous
Re: EXTI Driver
Post by Tabulous »
I've found the issue :-)
In low level driver function
ext_lld_channel_enable
You setup in this order the
EXTI->RTSR
EXTI->FTSR
EXTI->IMR
EXTI->EMR
and finally
SYSCFG->EXTICR
I dont think this is the correct way, It should be
SYSCFG->EXTICR
EXTI->RTSR
EXTI->FTSR
EXTI->IMR
EXTI->EMR
i'm not 100% sure why this fixes the issue, but if you look at the STM Lib code this is how they do it, i that order.
Below is revised ext_lld_channel_enable call, that now works
void ext_lld_channel_enable(EXTDriver *extp, expchannel_t channel) {
  /* Setting the associated GPIO for external channels.*/
  if (channel < 16) {
    uint32_t n = channel >> 2;
    uint32_t mask = ~(0xF << ((channel & 3) * 4));
    uint32_t port = ((extp->config->channels[channel].mode &
                      EXT_MODE_GPIO_MASK) >>
                     EXT_MODE_GPIO_OFF) << ((channel & 3) * 4);
#if defined(STM32L1XX_MD) || defined(STM32F0XX) || defined(STM32F2XX) ||    \
    defined(STM32F30X) || defined(STM32F37X) || defined(STM32F4XX)
  SYSCFG->EXTICR[n] = (SYSCFG->EXTICR[n] & mask) | port;
#else /* STM32F1XX */
  AFIO->EXTICR[n] = (AFIO->EXTICR[n] & mask) | port;
#endif /* STM32F1XX */
#if STM32_EXTI_NUM_CHANNELS > 32
  if (channel < 32) {
    /* Programming edge registers.*/
    if (extp->config->channels[channel].mode & EXT_CH_MODE_RISING_EDGE)
      EXTI->RTSR |= (1 << channel);
    else
      EXTI->RTSR &= ~(1 << channel);
    if (extp->config->channels[channel].mode & EXT_CH_MODE_FALLING_EDGE)
      EXTI->FTSR |= (1 << channel);
    else
      EXTI->FTSR &= ~(1 << channel);
    /* Programming interrupt and event registers.*/
    if (extp->config->channels[channel].cb != NULL) {
      EXTI->IMR |= (1 << channel);
      EXTI->EMR &= ~(1 << channel);
    else {
      EXTI->EMR |= (1 << channel);
      EXTI->IMR &= ~(1 << channel);
  else {
      EXTI->RTSR2 |= (1 << (32 - channel));
    else
      EXTI->RTSR2 &= ~(1 << (32 - channel));
      EXTI->FTSR2 |= (1 << (32 - channel));
    else
      EXTI->FTSR2 &= ~(1 << (32 - channel));
      EXTI->IMR2 |= (1 << (32 - channel));
      EXTI->EMR2 &= ~(1 << (32 - channel));
    else {
      EXTI->EMR2 |= (1 << (32 - channel));
      EXTI->IMR2 &= ~(1 << (32 - channel));
