[possible BUG] Bug 458 might not be fixed completely Topic is solved
dhampir
Re: [possible BUG] Bug 458 might not be fixed completely
Post by dhampir »
I changed the code and started the system. Lets see what happens :)
shinelikerain
Post by shinelikerain »
Did you get anywhere with this?
I cant write to a card as the driver fails in sdc_lld_wait_transaction_end() because of:-
 if ((SDIO->STA & SDIO_STA_DATAEND) == 0) {
    osalSysUnlock();
    return HAL_FAILED;
I'm using a STM32F407 DISCO with the STM32F4DISCOVERY Base Board. The tried the testhal() too and that also fails.
Could you try the workaround I proposed few posts before?
shinelikerain
I changed to:-
 while ((SDIO->STA & SDIO_STA_DATAEND) == 0)
And it hangs there. Reads are fine, writes always fail.
Thanks for info, I will give it a try again.
Could you provide some info about your setup? I need to replicate the problem.
shinelikerain
I took your ChibiOS 3 demo RT-STM32F407-DISCOVERY and modified board.h to allow SD3, Ethernet and SD Card on the STM32F4DISCOVERY Base Board.
I have lwIP and FatFs in the build and the makefile has -O0 for debug.
SD Card is a SanDisk Ultra. Reads have always worked 100% but when I came to use writes to support lwIP CGI I've hit this problem.
Many thanks Giovanni
Does it happen for each single write or it is a random event?
shinelikerain
It always fails for writes :(
Please post your board files, I suspect the problem could be there.
shinelikerain
Here they are Giovanni.
Thank you for your help.
ST_STM32F4_DISCOVERY_BB.rar
(6.44 KiB) Downloaded 545 times
