Page 2 of 2
Re: low-level TIM conflict with Chibio?
Posted: Tue Apr 22, 2014 3:59 pm
What compiler/version are you using? is FP enabled in your application?
Posted: Tue Apr 22, 2014 4:06 pm
by russian
I am using latest codesourcery - that's GCC 4.8.x. Yes I use floating point, and most of my logic (and stack usage) in in the interrupt handlers.
While I would probably need to increase even the proposed larger defaults, I still believe the current extremely low defaults are not perfect, they are probably causing issues for too many unsuspecting naive users.
Posted: Wed May 07, 2014 10:12 pm
by russian
Probably not related to Chibi at all, here's another issue I am having with the same code:
I am not getting an interrupt in case of small auto-reload register value:
void initMicrosecondTimer(void) {
   RCC ->APB1ENR |= RCC_APB1ENR_TIM5EN;   // Enable TIM5 clock
   nvicEnableVector(HW_TIMER_IRQ, CORTEX_PRIORITY_MASK(HW_TIMER_PRIORITY));
   TIM->DIER |= TIM_DIER_UIE;   // Enable interrupt on update event
   TIM->CR1 |= TIM_CR1_OPM; // one pulse mode: count down ARR and stop
   TIM->CR1 &= ~TIM_CR1_ARPE; /* ARR register is NOT buffered, allows to update timer's period on-fly. */
   TIM->PSC = 84 - 1;   // 168MHz / 2 / 84 = 1MHz, each tick is a microsecond
 * sets the alarm to the specified number of microseconds from now.
 * This function should be invoked under kernel lock which would disable interrupts.
void setHardwareUsTimer(int timeUs) {
   TIM->ARR = timeUs - 1;
   TIM->EGR |= TIM_EGR_UG; // generate an update event to reload timer's counter value
   TIM->CR1 |= TIM_CR1_CEN; // restart timer
   lastSetTimerTime = getTimeNowUs();
   isTimerPending = TRUE;
   timerRestartCounter++;
So, everything works as a charm if timeUs is 300 and above - that's 300us between timer restart and the callback. But if I try values like 5 or 11 - the callback never happens. Just for clarity: I am not even trying to constantly invoke 5us, 5us, 5us, 5us - even a single 5us after numerous 300us invocations fails to produce a callback.
Currently I am trying relatively low #define HW_TIMER_PRIORITY 12 but I was still expecting the callback to happen eventually?
Please advice how can I get the callback to happen, even if it would be a bit late.
Posted: Wed May 07, 2014 10:58 pm
What are you trying to do? it looks something like the GPT driver.
Posted: Thu May 08, 2014 3:45 am
by russian
Yes that's pretty much gptStartOneShot, I've forgotten what has scared me away from using it, let me give it a try :)
Posted: Fri May 09, 2014 2:37 am
by russian
I've migrated my code to gptStartOneShot and things are looking up.
Only one question: 'interval period in ticks'
Is it supposed to work as "gptStartOneShotI(&GPTDEVICE, 1);" - i.e. with interval = 1? Because it does not work for me like that - the callback never happens. Works with any other parameter.
I know that the implementation is
  gptp->tim->ARR   = (uint32_t)(interval - 1);  /* Time constant.           */
but one tick seems to be a valid parameter, is not it?
Posted: Fri May 09, 2014 8:10 am
Not sure if it is valid, have to look into the RM.
