[DONE] Broken RTC on ChibiOS 3
Re: [DONE] Broken RTC on ChibiOS 3
Fix committed.
Michail
Post by Michail »
Thanks, but that's not all :)
You forgot to change in line 222
#define STM32_RTC_HAS_PERIODIC_WAKEUPS      TRUE
to "FALSE" for #elif defined(STM32F0XX_LD)
so now I've
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.c:392:23: error: 'RTC_CR_WUTE' undeclared (first use in this function)
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.c:393:31: error: 'RTC_ISR_WUTWF' undeclared (first use in this function)
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.c:395:14: error: 'RTC_TypeDef' has no member named 'WUTR'
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.c:397:22: error: 'RTC_CR_WUTIE' undeclared (first use in this function)
       [cc] C:\Work\CoIDE\ChibiOS_3.0_Test\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.c:419:32: error: 'RTC_TypeDef' has no member named 'WUTR'
Thanks, fixed.
Michail
Post by Michail »
Got it, thank you. Now everything compiles fine!
