The changes will go in version 3.0, I think you should use that branch if you want to use newer STM32s. In 3.0 the registry is a separate file: stm32_registry.h
STM32F411 support
Re: STM32F411 support
please note that some changes are still to be made in the hal.
I have to enable all hal drivers and see where some more #ifdefs are required e.g. the ext driver will probably need some.
I understand that maintaining two separate versions is not desirable but isn't the 2.6 branch still the one for production use?
If you say 2.6. will not get newer chip support, i will redo the changes in the 3.0 branch if that helps.
Cheers,
Vincent
Cheers,
Vincent
Lets do this first for 3.0 then I will consider if doing the same in 2.6, the HAL is structured differently so the port is not immediate.
I started working on the v3 branch.
There are a couple of bug fixes for stm32f401 support.
You can grab them from here: https://github.com/lilvinz/ChibiOS-RT/c ... 411?page=1
Cheers,
Vinz
Cheers,
Vinz
After having looked at the v3 sources some time i have two questions:
- There is some half way support for stm32f2xx. No CMSIS headers but remainings? in ports/STM32/STM32F4xx e.g. hal_lld.h.
What is the state of this? Do you want to separate F2 from F4? If so, the remainings should be removed. If not, support should be restored.
I am asking this because it is a blocker for some of my projects to move from 2.6 to 3.0 and i am willing to push f2 support.
- What is your favorite solution regarding the once again changed constants in the ST headers?
Do you prefer to switch over everything to the new constants or do you prefer a preprocessor based solution e.g. in hal_lld.h?
I am asking to prevent redundant work on this one.
Cheers,
Vinz
Cheers,
Vinz
The idea is to keep F2 and F4 in the same HAL, those are too similar for duplicating all the code.
Tomorrow I will give that code a look and will have a more clear idea about it.
Sorry for the delay... busy week.
I merged the new header for the F4 from the STM32F4Cube software, I used a trick to keep drivers compatible with previous definitions, apparently everything is fine.
There are two things to add in hal_lld.h and the fixes in stm32_registry.h in order to support the F411, do you mind giving it a try? I don't have HW right now.
I plan updating also the other families in the same way.
A couple of things to fix:
* F401 doesn't have EXTI 19 and EXTI 20 but has EXTI 21 - this has to be fixed at ext_lld_isr.c and ext_ldd_isr.h
* F411 has the same EXTI limitations as F401
* F411 registry is missing (https://github.com/lilvinz/ChibiOS-RT/c ... ba71308027)
* F411 hal_lld.h flash waitstate and VOS configration is missing (https://github.com/lilvinz/ChibiOS-RT/c ... f8045e0b12)
* F411 linker scripts are missing
Besides that, i can't link using gcc and lto as gcc crashes. I will probably report that to https://bugs.launchpad.net/gcc-arm-embedded .
Cheers
Vinz
Cheers
Vinz
