Page 2 of 2
Re: STM32F100 on STM32VL Discovery - PWM complementary
Posted: Thu Nov 20, 2014 8:19 pm
by bartocham
So the setting should be like:
static PWMConfig pwmcfg = {
  10000, /* 10Khz PWM clock frequency */
  10,
  NULL,  /* No callback */
  /* Only channel 1 enabled */
    {PWM_OUTPUT_ACTIVE_HIGH | PWM_COMPLEMENTARY_OUTPUT_ACTIVE_HIGH, NULL},
    {PWM_OUTPUT_DISABLED, NULL},
  0,
  0,
#if STM32_PWM_USE_ADVANCED
  0
 /* Enables PWM output (of TIM1, channel 1) on LED connected to PA8 */
  palSetPadMode(GPIOA, 8, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
  /* Enables PWM output (of TIM1, channel 1N) on LED connected to PB13 */
  palSetPadMode(GPIOB, 13, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
  pwmStart(&PWMD1, &pwmcfg);
  pwmEnableChannel(&PWMD1, 0, 100);
Posted: Thu Nov 20, 2014 8:26 pm
Note that you set the period to 10 this means that you have 11 integer duty cycle settings for your PWM: 0...10. This means that you cannot set the duty cycle to 100, 10 is the maximum.
Both the period and the duty cycle are expressed as number of clock cycles.
Posted: Wed Nov 26, 2014 12:29 pm
by bartocham
Hi Giovani,
Now it is clear. I'm wondering if it is possible to get 500kHz signal. Can I set PWMConfig like this:
  5000000, /* 5MHz PWM clock frequency */
  10,
  0,
  0,
  0
  pwmEnableChannel(&PWMD1, 0, 5);
Posted: Wed Nov 26, 2014 1:48 pm
The clock frequency must be something you can obtain from the timer clock using an integer divider, so no.
If you try that an assertion will block you in pwmStart().
Posted: Wed Nov 26, 2014 2:13 pm
by bartocham
So maybe you have some idea how to obtain that kind of PWM frequency?
Posted: Wed Nov 26, 2014 2:17 pm
Clocking the device to a frequency that can be divided by 5000000.
