thanks for pin pointing me, I got it working
best,
kiwi
/* ChibiOS */
#include "ch.h"
/* FatFS */
#include "ff.h"
#include "main.h"
FATFS SDC_FS;
/* SDCDriver config. */
static SDCConfig sdccfg = {0};
int main(void)
/* Initialize SDCard over SDIO */
sdcObjectInit(&SDCD1);
sdcStart(&SDCD1, &sdccfg);
if(sdcConnect(&SDCD1) == CH_SUCCESS) {
if(f_mount(0, &SDC_FS) == FR_OK) {
FIL file;
UINT written;
if(f_open(&file, "test.txt", FA_CREATE_ALWAYS) == FR_OK) {
f_write(&file, (void*)"a", 8, &written);
f_close(&file);
while(TRUE) {
chThdSleepMilliseconds(500);
return 1;
#define GPIOC_FMC_SDNWE 0
#define GPIOC_SPI5_MEMS_CS 1
#define GPIOC_SPI5_LCD_CS 2
#define GPIOC_PIN3 3
#define GPIOC_OTG_HS_PSO 4
#define GPIOC_OTG_HS_OC 5
#define GPIOC_LCD_HSYNC 6
#define GPIOC_LCD_G6 7
#define GPIOC_SD_D0 8
#define GPIOC_SD_D1 9
#define GPIOC_SD_D2 10
#define GPIOC_SD_D3 11
#define GPIOC_SD_CLK 12
#define GPIOC_PIN13 13
#define GPIOC_OSC32_IN 14
#define GPIOC_OSC32_OUT 15
* GPIOC setup:
* PC0 - FMC_SDNWE (alternate 12).
* PC1 - SPI5_MEMS_CS (output pushpull maximum).
* PC2 - SPI5_LCD_CS (output pushpull maximum).
* PC3 - PIN3 (input pullup).
* PC4 - OTG_HS_PSO (output pushpull maximum).
* PC5 - OTG_HS_OC (input floating).
* PC6 - LCD_HSYNC (alternate 14).
* PC7 - LCD_G6 (alternate 14).
* PC8 - SD_D0 (alternate 12).
* PC9 - SD_D1 (alternate 12).
* PC10 - SD_D2 (alternate 12).
* PC11 - SD_D3 (alternate 12).
* PC12 - SD_CLK (alternate 12).
* PC13 - PIN13 (input pullup).
* PC14 - OSC32_IN (input floating).
* PC15 - OSC32_OUT (input floating).
#define VAL_GPIOC_MODER (PIN_MODE_ALTERNATE(GPIOC_FMC_SDNWE) | \
PIN_MODE_OUTPUT(GPIOC_SPI5_MEMS_CS) | \
PIN_MODE_OUTPUT(GPIOC_SPI5_LCD_CS) | \
PIN_MODE_INPUT(GPIOC_PIN3) | \
PIN_MODE_OUTPUT(GPIOC_OTG_HS_PSO) | \
PIN_MODE_INPUT(GPIOC_OTG_HS_OC) | \
PIN_MODE_ALTERNATE(GPIOC_LCD_HSYNC) | \
PIN_MODE_ALTERNATE(GPIOC_LCD_G6) | \
PIN_MODE_ALTERNATE(GPIOC_SD_D0) | \
PIN_MODE_ALTERNATE(GPIOC_SD_D1) | \
PIN_MODE_ALTERNATE(GPIOC_SD_D2) | \
PIN_MODE_ALTERNATE(GPIOC_SD_D3) | \
PIN_MODE_ALTERNATE(GPIOC_SD_CLK) | \
PIN_MODE_INPUT(GPIOC_PIN13) | \
PIN_MODE_INPUT(GPIOC_OSC32_IN) | \
PIN_MODE_INPUT(GPIOC_OSC32_OUT))
#define VAL_GPIOC_OTYPER (PIN_OTYPE_PUSHPULL(GPIOC_FMC_SDNWE) | \
PIN_OTYPE_PUSHPULL(GPIOC_SPI5_MEMS_CS) |\
PIN_OTYPE_PUSHPULL(GPIOC_SPI5_LCD_CS) |\
PIN_OTYPE_PUSHPULL(GPIOC_PIN3) | \
PIN_OTYPE_PUSHPULL(GPIOC_OTG_HS_PSO) | \
PIN_OTYPE_PUSHPULL(GPIOC_OTG_HS_OC) | \
PIN_OTYPE_PUSHPULL(GPIOC_LCD_HSYNC) | \
PIN_OTYPE_PUSHPULL(GPIOC_LCD_G6) | \
PIN_OTYPE_PUSHPULL(GPIOC_SD_D0) | \
PIN_OTYPE_PUSHPULL(GPIOC_SD_D1) | \
PIN_OTYPE_PUSHPULL(GPIOC_SD_D2) | \
PIN_OTYPE_PUSHPULL(GPIOC_SD_D3) | \
PIN_OTYPE_PUSHPULL(GPIOC_SD_CLK) | \
PIN_OTYPE_PUSHPULL(GPIOC_PIN13) | \
PIN_OTYPE_PUSHPULL(GPIOC_OSC32_IN) | \
PIN_OTYPE_PUSHPULL(GPIOC_OSC32_OUT))
#define VAL_GPIOC_OSPEEDR (PIN_OSPEED_100M(GPIOC_FMC_SDNWE) | \
PIN_OSPEED_100M(GPIOC_SPI5_MEMS_CS) | \
PIN_OSPEED_100M(GPIOC_SPI5_LCD_CS) | \
PIN_OSPEED_2M(GPIOC_PIN3) | \
PIN_OSPEED_100M(GPIOC_OTG_HS_PSO) | \
PIN_OSPEED_100M(GPIOC_OTG_HS_OC) | \
PIN_OSPEED_100M(GPIOC_LCD_HSYNC) | \
PIN_OSPEED_100M(GPIOC_LCD_G6) | \
PIN_OSPEED_100M(GPIOC_SD_D0) | \
PIN_OSPEED_100M(GPIOC_SD_D1) | \
PIN_OSPEED_100M(GPIOC_SD_D2) | \
PIN_OSPEED_100M(GPIOC_SD_D3) | \
PIN_OSPEED_100M(GPIOC_SD_CLK) | \
PIN_OSPEED_2M(GPIOC_PIN13) | \
PIN_OSPEED_100M(GPIOC_OSC32_IN) | \
PIN_OSPEED_100M(GPIOC_OSC32_OUT))
#define VAL_GPIOC_PUPDR (PIN_PUPDR_FLOATING(GPIOC_FMC_SDNWE) | \
PIN_PUPDR_FLOATING(GPIOC_SPI5_MEMS_CS) |\
PIN_PUPDR_FLOATING(GPIOC_SPI5_LCD_CS) |\
PIN_PUPDR_PULLUP(GPIOC_PIN3) | \
PIN_PUPDR_FLOATING(GPIOC_OTG_HS_PSO) | \
PIN_PUPDR_FLOATING(GPIOC_OTG_HS_OC) | \
PIN_PUPDR_FLOATING(GPIOC_LCD_HSYNC) | \
PIN_PUPDR_FLOATING(GPIOC_LCD_G6) | \
PIN_PUPDR_FLOATING(GPIOC_SD_D0) | \
PIN_PUPDR_FLOATING(GPIOC_SD_D1) | \
PIN_PUPDR_FLOATING(GPIOC_SD_D2) | \
PIN_PUPDR_FLOATING(GPIOC_SD_D3) | \
PIN_PUPDR_FLOATING(GPIOC_SD_CLK) | \
PIN_PUPDR_PULLUP(GPIOC_PIN13) | \
PIN_PUPDR_FLOATING(GPIOC_OSC32_IN) | \
PIN_PUPDR_FLOATING(GPIOC_OSC32_OUT))
#define VAL_GPIOC_ODR (PIN_ODR_HIGH(GPIOC_FMC_SDNWE) | \
PIN_ODR_HIGH(GPIOC_SPI5_MEMS_CS) | \
PIN_ODR_HIGH(GPIOC_SPI5_LCD_CS) | \
PIN_ODR_HIGH(GPIOC_PIN3) | \
PIN_ODR_HIGH(GPIOC_OTG_HS_PSO) | \
PIN_ODR_HIGH(GPIOC_OTG_HS_OC) | \
PIN_ODR_HIGH(GPIOC_LCD_HSYNC) | \
PIN_ODR_HIGH(GPIOC_LCD_G6) | \
PIN_ODR_HIGH(GPIOC_SD_D0) | \
PIN_ODR_HIGH(GPIOC_SD_D1) | \
PIN_ODR_HIGH(GPIOC_SD_D2) | \
PIN_ODR_HIGH(GPIOC_SD_D3) | \
PIN_ODR_HIGH(GPIOC_SD_CLK) | \
PIN_ODR_HIGH(GPIOC_PIN13) | \
PIN_ODR_HIGH(GPIOC_OSC32_IN) | \
PIN_ODR_HIGH(GPIOC_OSC32_OUT))
#define VAL_GPIOC_AFRL (PIN_AFIO_AF(GPIOC_FMC_SDNWE, 12) | \
PIN_AFIO_AF(GPIOC_SPI5_MEMS_CS, 0) | \
PIN_AFIO_AF(GPIOC_SPI5_LCD_CS, 0) | \
PIN_AFIO_AF(GPIOC_PIN3, 0) | \
PIN_AFIO_AF(GPIOC_OTG_HS_PSO, 0) | \
PIN_AFIO_AF(GPIOC_OTG_HS_OC, 0) | \
PIN_AFIO_AF(GPIOC_LCD_HSYNC, 14) | \
PIN_AFIO_AF(GPIOC_LCD_G6, 14))
#define VAL_GPIOC_AFRH (PIN_AFIO_AF(GPIOC_SD_D0, 12) | \
PIN_AFIO_AF(GPIOC_SD_D1, 12) | \
PIN_AFIO_AF(GPIOC_SD_D2, 12) | \
PIN_AFIO_AF(GPIOC_SD_D3, 12) | \
PIN_AFIO_AF(GPIOC_SD_CLK, 12) | \
PIN_AFIO_AF(GPIOC_PIN13, 0) | \
PIN_AFIO_AF(GPIOC_OSC32_IN, 0) | \
PIN_AFIO_AF(GPIOC_OSC32_OUT, 0))
#define GPIOD_FMC_D2 0
#define GPIOD_FMC_D3 1
#define GPIOD_SD_CMD 2
#define GPIOD_LCD_G7 3
#define GPIOD_PIN4 4
#define GPIOD_PIN5 5
#define GPIOD_LCD_B2 6
#define GPIOD_PIN7 7
#define GPIOD_FMC_D13 8
#define GPIOD_FMC_D14 9
#define GPIOD_FMC_D15 10
#define GPIOD_LCD_TE 11
#define GPIOD_LCD_RDX 12
#define GPIOD_LCD_WRX 13
#define GPIOD_FMC_D0 14
#define GPIOD_FMC_D1 15
* GPIOD setup:
* PD0 - FMC_D2 (alternate 12).
* PD1 - FMC_D3 (alternate 12).
* PD2 - SD_CMD (alternate 12).
* PD3 - LCD_G7 (alternate 14).
* PD4 - PIN4 (input pullup).
* PD5 - PIN5 (input pullup).
* PD6 - LCD_B2 (alternate 14).
* PD7 - PIN7 (input pullup).
* PD8 - FMC_D13 (alternate 12).
* PD9 - FMC_D14 (alternate 12).
* PD10 - FMC_D15 (alternate 12).
* PD11 - LCD_TE (input floating).
* PD12 - LCD_RDX (output pushpull maximum).
* PD13 - LCD_WRX (output pushpull maximum).
* PD14 - FMC_D0 (alternate 12).
* PD15 - FMC_D1 (alternate 12).
#define VAL_GPIOD_MODER (PIN_MODE_ALTERNATE(GPIOD_FMC_D2) | \
PIN_MODE_ALTERNATE(GPIOD_FMC_D3) | \
PIN_MODE_ALTERNATE(GPIOD_SD_CMD) | \
PIN_MODE_ALTERNATE(GPIOD_LCD_G7) | \
PIN_MODE_INPUT(GPIOD_PIN4) | \
PIN_MODE_INPUT(GPIOD_PIN5) | \
PIN_MODE_ALTERNATE(GPIOD_LCD_B2) | \
PIN_MODE_INPUT(GPIOD_PIN7) | \
PIN_MODE_ALTERNATE(GPIOD_FMC_D13) | \
PIN_MODE_ALTERNATE(GPIOD_FMC_D14) | \
PIN_MODE_ALTERNATE(GPIOD_FMC_D15) | \
PIN_MODE_INPUT(GPIOD_LCD_TE) | \
PIN_MODE_OUTPUT(GPIOD_LCD_RDX) | \
PIN_MODE_OUTPUT(GPIOD_LCD_WRX) | \
PIN_MODE_ALTERNATE(GPIOD_FMC_D0) | \
PIN_MODE_ALTERNATE(GPIOD_FMC_D1))
#define VAL_GPIOD_OTYPER (PIN_OTYPE_PUSHPULL(GPIOD_FMC_D2) | \
PIN_OTYPE_PUSHPULL(GPIOD_FMC_D3) | \
PIN_OTYPE_PUSHPULL(GPIOD_SD_CMD) | \
PIN_OTYPE_PUSHPULL(GPIOD_LCD_G7) | \
PIN_OTYPE_PUSHPULL(GPIOD_PIN4) | \
PIN_OTYPE_PUSHPULL(GPIOD_PIN5) | \
PIN_OTYPE_PUSHPULL(GPIOD_LCD_B2) | \
PIN_OTYPE_PUSHPULL(GPIOD_PIN7) | \
PIN_OTYPE_PUSHPULL(GPIOD_FMC_D13) | \
PIN_OTYPE_PUSHPULL(GPIOD_FMC_D14) | \
PIN_OTYPE_PUSHPULL(GPIOD_FMC_D15) | \
PIN_OTYPE_PUSHPULL(GPIOD_LCD_TE) | \
PIN_OTYPE_PUSHPULL(GPIOD_LCD_RDX) | \
PIN_OTYPE_PUSHPULL(GPIOD_LCD_WRX) | \
PIN_OTYPE_PUSHPULL(GPIOD_FMC_D0) | \
PIN_OTYPE_PUSHPULL(GPIOD_FMC_D1))
#define VAL_GPIOD_OSPEEDR (PIN_OSPEED_100M(GPIOD_FMC_D2) | \
PIN_OSPEED_100M(GPIOD_FMC_D3) | \
PIN_OSPEED_100M(GPIOD_SD_CMD) | \
PIN_OSPEED_100M(GPIOD_LCD_G7) | \
PIN_OSPEED_2M(GPIOD_PIN4) | \
PIN_OSPEED_2M(GPIOD_PIN5) | \
PIN_OSPEED_100M(GPIOD_LCD_B2) | \
PIN_OSPEED_2M(GPIOD_PIN7) | \
PIN_OSPEED_100M(GPIOD_FMC_D13) | \
PIN_OSPEED_100M(GPIOD_FMC_D14) | \
PIN_OSPEED_100M(GPIOD_FMC_D15) | \
PIN_OSPEED_100M(GPIOD_LCD_TE) | \
PIN_OSPEED_100M(GPIOD_LCD_RDX) | \
PIN_OSPEED_100M(GPIOD_LCD_WRX) | \
PIN_OSPEED_100M(GPIOD_FMC_D0) | \
PIN_OSPEED_100M(GPIOD_FMC_D1))
#define VAL_GPIOD_PUPDR (PIN_PUPDR_FLOATING(GPIOD_FMC_D2) | \
PIN_PUPDR_FLOATING(GPIOD_FMC_D3) | \
PIN_PUPDR_FLOATING(GPIOD_SD_CMD) | \
PIN_PUPDR_FLOATING(GPIOD_LCD_G7) | \
PIN_PUPDR_PULLUP(GPIOD_PIN4) | \
PIN_PUPDR_PULLUP(GPIOD_PIN5) | \
PIN_PUPDR_FLOATING(GPIOD_LCD_B2) | \
PIN_PUPDR_PULLUP(GPIOD_PIN7) | \
PIN_PUPDR_FLOATING(GPIOD_FMC_D13) | \
PIN_PUPDR_FLOATING(GPIOD_FMC_D14) | \
PIN_PUPDR_FLOATING(GPIOD_FMC_D15) | \
PIN_PUPDR_FLOATING(GPIOD_LCD_TE) | \
PIN_PUPDR_FLOATING(GPIOD_LCD_RDX) | \
PIN_PUPDR_FLOATING(GPIOD_LCD_WRX) | \
PIN_PUPDR_FLOATING(GPIOD_FMC_D0) | \
PIN_PUPDR_FLOATING(GPIOD_FMC_D1))
#define VAL_GPIOD_ODR (PIN_ODR_HIGH(GPIOD_FMC_D2) | \
PIN_ODR_HIGH(GPIOD_FMC_D3) | \
PIN_ODR_HIGH(GPIOD_SD_CMD) | \
PIN_ODR_HIGH(GPIOD_LCD_G7) | \
PIN_ODR_HIGH(GPIOD_PIN4) | \
PIN_ODR_HIGH(GPIOD_PIN5) | \
PIN_ODR_HIGH(GPIOD_LCD_B2) | \
PIN_ODR_HIGH(GPIOD_PIN7) | \
PIN_ODR_HIGH(GPIOD_FMC_D13) | \
PIN_ODR_HIGH(GPIOD_FMC_D14) | \
PIN_ODR_HIGH(GPIOD_FMC_D15) | \
PIN_ODR_HIGH(GPIOD_LCD_TE) | \
PIN_ODR_HIGH(GPIOD_LCD_RDX) | \
PIN_ODR_HIGH(GPIOD_LCD_WRX) | \
PIN_ODR_HIGH(GPIOD_FMC_D0) | \
PIN_ODR_HIGH(GPIOD_FMC_D1))
#define VAL_GPIOD_AFRL (PIN_AFIO_AF(GPIOD_FMC_D2, 12) | \
PIN_AFIO_AF(GPIOD_FMC_D3, 12) | \
PIN_AFIO_AF(GPIOD_SD_CMD, 12) | \
PIN_AFIO_AF(GPIOD_LCD_G7, 14) | \
PIN_AFIO_AF(GPIOD_PIN4, 0) | \
PIN_AFIO_AF(GPIOD_PIN5, 0) | \
PIN_AFIO_AF(GPIOD_LCD_B2, 14) | \
PIN_AFIO_AF(GPIOD_PIN7, 0))
#define VAL_GPIOD_AFRH (PIN_AFIO_AF(GPIOD_SD_CMD, 12) | \
PIN_AFIO_AF(GPIOD_FMC_D13, 12) | \
PIN_AFIO_AF(GPIOD_FMC_D14, 12) | \
PIN_AFIO_AF(GPIOD_FMC_D15, 12) | \
PIN_AFIO_AF(GPIOD_LCD_TE, 0) | \
PIN_AFIO_AF(GPIOD_LCD_RDX, 0) | \
PIN_AFIO_AF(GPIOD_LCD_WRX, 0) | \
PIN_AFIO_AF(GPIOD_FMC_D0, 12) | \
PIN_AFIO_AF(GPIOD_FMC_D1, 12))
