Page 2 of 6
Re: Threads are dying, I cannot find the issue :(
Posted: Fri Feb 27, 2015 6:56 pm
by russian
Ops, sorry - that's my helper wrapper over Chibi API:
void chVTSetAny(virtual_timer_t *vtp, systime_t time, vtfunc_t vtfunc, void *par) {
if (isIsrContext()) {
bool wasLocked = lockAnyContext();
* todo: this could be simplified once we migrate to ChibiOS 3.0
* See http://www.chibios.org/dokuwiki/doku.php?id=chibios:howtos:porting_from_2_to_3
if (chVTIsArmedI(vtp))
chVTResetI(vtp);
chVTSetI(vtp, time, vtfunc, par);
if (!wasLocked)
chSysUnlockFromIsr();
} else {
chSysLock();
chVTResetI(vtp);
chSysUnlock();
Posted: Fri Feb 27, 2015 8:18 pm
chSysLockFromIsr() is missing from that function.
Posted: Fri Feb 27, 2015 8:23 pm
by russian
I think lockAnyContext takes care of that
* @return TRUE if already in locked context
bool lockAnyContext(void) {
int alreadyLocked = isLocked();
if (alreadyLocked)
return true;
chSysLockFromIsr()
} else {
chSysLock()
return false;
Posted: Fri Feb 27, 2015 8:26 pm
I don't understand that code much, I am not sure if there is a problem there. Probably you are better off using the normal lock and unlock primitives.
Is the state checker active?
Posted: Fri Feb 27, 2015 8:35 pm
by russian
russian wrote:Some details:
__main_stack_size__ = 0x1000;
__process_stack_size__ = 0x0600;
#define PORT_IDLE_THREAD_STACK_SIZE 1024
#define PORT_INT_REQUIRED_STACK 32
#define CH_DBG_ENABLE_STACK_CHECK TRUE
#define CH_DBG_ENABLE_CHECKS TRUE
#define CH_DBG_ENABLE_ASSERTS TRUE
#define CH_DBG_SYSTEM_STATE_CHECK TRUE
Yes, all the state checks are enabled:
#define CH_DBG_ENABLE_TRACE TRUE
Posted: Fri Feb 27, 2015 9:05 pm
by russian
Hopefully my helper method is more readable now:
if (chVTIsArmedI(vtp)) {
chVTResetI(vtp);
if (!wasLocked) {
unlockAnyContext();
To be honest the locking here is the thing I am least concerned, I am using the same
...code to guard...
if (!wasLocked) {
unlockAnyContext();
pattern a lot and in my understanding it's bulletproof
Posted: Mon Mar 02, 2015 5:22 am
by russian
In order to get chibi state via the plugin I've installed ChibiStudio - and suddenly I was not able to reproduce the issue.
I know it might sound lame and wishful thinking, but it seems like using 4.9.3 AND fresh version of a makefile makes the issue either disappear or at least become much, much less often.
my older 4.8.3 with my makefile (based on older chibi makefile) fails after some iterations. my makefile with 4.9.3 fails after some iterations. it has to be 4.9.3 AND fresh chibi makefile
I wound understand if compiler would be creating faulty code, but how is it possible that compiler version or compiler options make a code which runs for 400 times and then fails? It's not like we have any JIT compilers here.
here's verbose of 'my' 'older' makefile:
arm-none-eabi-g++ -c -mcpu=cortex-m4 -std=c++11 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -Werror=write-strings -Werror=type-limits -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -Wall -Wextra -Wa,-alms=build/lst/main.lst -DST_STM32F4_DISCOVERY -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -MD -MP -MF .dep/main.o.d -mthumb -DTHUMB -I. -Ichibios/os/ports/common/ARMCMx/CMSIS/include -Ichibios/os/ports/common/ARMCMx -Ichibios/os/ports/GCC/ARMCMx -Ichibios/os/ports/GCC/ARMCMx/STM32F4xx -Ichibios/os/kernel/include -Ichibios/os/hal/include -Ichibios/os/hal/platforms/STM32F4xx -Ichibios/os/hal/platforms/STM32 -Ichibios/os/hal/platforms/STM32/GPIOv2 -Ichibios/os/hal/platforms/STM32/I2Cv1 -Ichibios/os/hal/platforms/STM32/OTGv1 -Ichibios/os/hal/platforms/STM32/RTCv2 -Ichibios/os/hal/platforms/STM32/SPIv1 -Ichibios/os/hal/platforms/STM32/TIMv1 -Ichibios/os/hal/platforms/STM32/USARTv1 -Ichibios/boards/ST_STM32F4_DISCOVERY -Ichibios/os/various/cpp_wrappers -Ichibios/os/various -Iconfig/stm32f4ems -Iconfig/engines -Iconfig -Ichibios/os/various -Iext -Iext_algo -Iutil -Iconsole_util -Iconsole -Iconsole/tunerstudio -Ihw_layer -Ihw_layer/serial_over_usb -Ihw_layer/algo -Ihw_layer/lcd -Ihw_layer/stm32f4 -Idevelopment -Idevelopment/hw_layer -Idevelopment/test -Icontrollers -Icontrollers/sensors -Icontrollers/system -Icontrollers/algo -Icontrollers/core -Icontrollers/math -Icontrollers/trigger main.cpp -o build/obj/main.o
here's verbose of newer chibi makefile adopted for my project;
arm-none-eabi-g++ -c -mcpu=cortex-m4 -O2 -ggdb -std=gnu99 -fomit-frame-pointer -falign-functions=16 -ffunction-sections -fdata-sections -fno-common -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -fsingle-precision-constant -std=c++11 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -Werror=write-strings -Werror=type-limits -Wall -Wextra -Wa,-alms=build/lst/main.lst -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -MD -MP -MF .dep/main.o.d -mthumb -DTHUMB -I. -Ichibios/os/ports/common/ARMCMx/CMSIS/include -Ichibios/os/ports/common/ARMCMx -Ichibios/os/ports/GCC/ARMCMx -Ichibios/os/ports/GCC/ARMCMx/STM32F4xx -Ichibios/os/kernel/include -Ichibios/os/hal/include -Ichibios/os/hal/platforms/STM32F4xx -Ichibios/os/hal/platforms/STM32 -Ichibios/os/hal/platforms/STM32/GPIOv2 -Ichibios/os/hal/platforms/STM32/I2Cv1 -Ichibios/os/hal/platforms/STM32/OTGv1 -Ichibios/os/hal/platforms/STM32/RTCv2 -Ichibios/os/hal/platforms/STM32/SPIv1 -Ichibios/os/hal/platforms/STM32/TIMv1 -Ichibios/os/hal/platforms/STM32/USARTv1 -Ichibios/boards/ST_STM32F4_DISCOVERY -Ichibios/os/various -Iconfig/stm32f4ems -Iconfig/engines -Iconfig -Ichibios/os/various -Iext -Iext_algo -Iutil -Iconsole_util -Iconsole -Iconsole/tunerstudio -Ihw_layer -Ihw_layer/serial_over_usb -Ihw_layer/algo -Ihw_layer/lcd -Ihw_layer/stm32f4 -Idevelopment -Idevelopment/hw_layer -Idevelopment/test -Icontrollers -Icontrollers/sensors -Icontrollers/system -Icontrollers/algo -Icontrollers/core -Icontrollers/math -Icontrollers/trigger main.cpp -o build/obj/main.o
some of the differences between makefiles are
-fno-common
I also have reports that 4.9.2 works with my 'older' style makefile. If the difference between 4.9.2 and 4.9.3 actually makes a difference it would be pretty upsetting.
I am logging the result of running same test with different makefiles and different compilers @
https://sourceforge.net/p/rusefi/tickets/155/
Posted: Mon Mar 02, 2015 9:09 am
It could be a compiler issue then.
About makefiles, you should always use those provided with the ChibiOS version you are using, same for all configuration files and scatter files.
Posted: Mon Mar 02, 2015 1:23 pm
by russian
I've left it overnight to run a 12000 iteration test chibi config and newer GCC compiler embedded with chibistudio, that seems as my most reliable setup
it has failed in 4:30 hours at 3712th iteration, this makes me think the compiler is only affecting the chance of the issue occurring, but it is still there.
Posted: Mon Mar 02, 2015 1:52 pm
by russian
IAR with the same exact source code has survived the night, it is now at iteration 7300ish.
