USB CDC + NIL osalThreadDequeueAllI assertion fail
ulikoehler
Re: USB CDC + NIL osalThreadDequeueAllI assertion fail
Post by ulikoehler »
Sorry for the late reply!
Yes, I think logically this fixes the bug. I think your fix is simpler than mine (and likely results in a smaller code size) and therefore should be used.
I'll try it out with my firmware in the next days and I'll let you know when I have any results.
Best regards, Uli
ulikoehler
Sorry again for the delay. I didn't have access to the USB adapter hardware before today.
As far as I can tell, the error doesn't occur any more with your changed source code on my hardware. I also think that your patch logically eliminates the bug, so +1 from me for applying that fix.
Best regards,
Uli
Thanks, marking as fixed then.
