Re: function Serial.attach()
Posted: Wed Oct 14, 2015 1:02 pm
hI AlSith my code is here:
i see this situetion if i avtive this thread
the event start but if i don't active this threads the event don't start, for this situetion now i see the uart driver.
bye
A.
static THD_WORKING_AREA(waRead5, 128);
static THD_FUNCTION(Thread5,arg) {
chRegSetThreadName("th_Riempio_Buffer");
msg_t charbuf;
// int count=0;
// char B2[] = "E_2";
// char B3[] = "E_3";
uint8_t c;
event_listener_t Uart1Data;
eventmask_t flags;
chEvtRegisterMask((event_source_t *)chnGetEventSource(&SD1), &Uart1Data, EVENT_MASK(1));
while (TRUE) {
chEvtWaitOneTimeout(EVENT_MASK(1), MS2ST(10));
chSysLock();
// flags = chEvtGetAndClearFlags(&Uart1Data);
flags =chEvtGetAndClearFlags(&Uart1Data);
chSysUnlock();
if (flags & CHN_INPUT_AVAILABLE)
// sdWrite(&SD2, (uint8_t *)B2,4); // va bene
do
charbuf = chnGetTimeout(&SD1,TIME_IMMEDIATE);
if (charbuf != Q_TIMEOUT)
while((charbuf != '\n') && (count < 128)) {
sdWrite(&SD2, (uint8_t *)B3,4); // va bene
bufferMsg[count]= charbuf;
count++;
// uint8_t c = sdGet(&SD1); //questo prende il carattere
if ( charbuf != Q_TIMEOUT )
chprintf(chp,(char)charbuf);
while (charbuf != Q_TIMEOUT);
/* Periodic thread for reading data */
/*Spara i dati */
static THD_WORKING_AREA(waRead, 128);
static THD_FUNCTION(Thread,arg) {
(void)arg;
chRegSetThreadName("th_callback");
while (TRUE){
/* This will wait for a character to be received */
sdPut(&SD2, c); // questo lo spara alla terminale
bye
A.
