Page 2 of 2
Re: GPT set frequency
Posted: Sat Dec 19, 2015 9:16 pm
Could you look at TIM2 registers and post values here? especially the prescaler and ARR.
Posted: Sun Dec 20, 2015 8:56 am
by fastlink30
attached register with all the values.
why tim2? gpt use tim8
if for irq priority i have already changed value for gpt8 (set to 11), but nothing change
- tim8-gpt.png (4.64 KiB) Viewed 3290 times
- tim2-pwm.png (4.61 KiB) Viewed 3290 times
Posted: Sun Dec 20, 2015 9:09 am
Sorry
the values of your timer of course.
Posted: Sun Dec 20, 2015 9:17 am
OK found the error....
I think you misunderstood the meaning of the frequency field in the configuration structure. It is not the frequency of the timer but the frequency driven into the timer counter (it is the resolution of the timer).
The final frequency, more appropriately the period, is what you pass to gptStartContinuous(), you set zero there and it is taken as 65536.
For example try setting the resolution to 1000000 (1uS) then pass to gptStartContinuous() the period you need in microseconds, for example 50 (20kHz).
Note that the PWM and ICU drivers work the same way.
It was obvious and in full sight yet perfectly invisible...
Posted: Sun Dec 20, 2015 9:32 am
by fastlink30
ahaaa
now it's clear!
sorry giovanni for your time & patience
thank you
