Sorry, I should have given a bit more info.
Use the LPC13xx port as a reference to how the code should be structured - this code is a modified version of that anyway.
And I would start from a clean Chibios checkout for two reasons:
1 - its easy to diff your changes against the current tree
2 - not sure what else you might catch......
Clock/PLL configuration
This is usually the hardest bit of a new port because if you get it wrong the device will probably do nothing at all....(and if the clock is fubar a debugger is no use either)
The xx_clock_init() function should set up the clocks/plls based on a set of config parameters. These parameters are configured in the application config file mcuconf.h. The set of config parameters, possible values and suitable default configuration are defined in hal_lld.h.
So, using the code in system_LPC17xx.c as a guide (and the LPC17xx user manual - don't assume that the code is correct!), come up with a set of defines (and suitable defaults) for hal_lld.h. I usually make the default a very simple case eg. internal OSC, no pll, minimal divider set-up so that it is pretty much always going to work.
Then use this set of defines and the code from system_LPC17xx.c to fill out LPC17xx_clock_init().
Try and be logical about it; if you examine the LPC13xx code you will see that it will only enable the system oscillator and configure the pll if the main system clock is set to be the pll output. Obvious really, but the original ARM code always tried to set-up the pll even if the oscillator wasn't enabled.
And finally, make sure you enable the clocks to the GPIO blocks.
GPIO driver (pal_lld)
I think that this will work.
Linker script
I'm assuming you are using GCC?
create this file: os / ports / GCC / ARMCMx / LPC17xx / ld / LPC1769.ld
The 1768 file should be fine to start off with and change the reference in the application makefile.
Board Files
Create a board directory: boards /<SOME-BOARD-NAME>/
Again copy the 1768 version - but think of a better name, look in the main chibios repository for some ideas. Inspect the three files and modify as appropriate, ie references in the makefile, default gpio setup in board.h.
Change the reference in the application makefile
and that's it - you now have a very basic, but functional, LPC1769 port that should at least be able to make the leds flash.
Have fun and if need any pointers (or find I've missed something) please let me know.
mike
