Reset reason
Re: Reset reason
Is it guaranteed that you find only one bit raised? Couldn't find this info.
Re: Reset reason
So this API could just report "external reset" or "other reset" and a mask of platform-dependent flags, the RCC_CSR register in the STM32 case.
Re: Reset reason
if you poll the CRS register in this order, you will know you reason for reset. Yes NRST is always set as every reset work by pulling NRST low for afew micro seconds, but it should be the last bit you poll.
Tested this and seems to work.
if( RCC->CSR & ( 1 << 31 ))
TGL_DEBUG( DBG_MASK_APP, "$ APP - RESET(PLWR)\r\n" );
else if( RCC->CSR & ( 1 << 30 ))
TGL_DEBUG( DBG_MASK_APP, "$ APP - RESET(WWDG)\r\n" );
else if( RCC->CSR & ( 1 << 29 ))
TGL_DEBUG( DBG_MASK_APP, "$ APP - RESET(IWDG)\r\n" );
else if( RCC->CSR & ( 1 << 28 ))
TGL_DEBUG( DBG_MASK_APP, "$ APP - RESET(SOFT)\r\n" );
else if( RCC->CSR & ( 1 << 27 ))
TGL_DEBUG( DBG_MASK_APP, "$ APP - RESET(POR)\r\n" );
else if( RCC->CSR & ( 1 << 26 ))
TGL_DEBUG( DBG_MASK_APP, "$ APP - RESET(NRST)\r\n" );
electronic_eel
- Has thanked: 8 times
- Been thanked: 23 times
Re: Reset reason
Is there already any HAL code for this available that I could test?
I'm just working on a project where I need to check if the watchdog triggered a reset and alert the user that something went wrong.
