It is a good idea to reduce the tick rate.
halconf and mcuconf for pwm: #error compile time
enrico.dallavia
- Has thanked: 2 times
Re: halconf and mcuconf for pwm: #error compile time
So, i have to change
#define CH_CFG_ST_FREQUENCY 10000
to
right?
to
right?
enrico.dallavia
Now that the pwm on TIM2 in working I have a little double about the duty cycle
I need a pwm from 1Hz to 20kHz.
I set the frequency of the timer to 1MHz
with a constant duty cycle of 50%
from the example
the 5000 parameter should be constant, since the formula is
tick = period * 5000/10000
so with period of 50 I need (I suppose) a result of 25 so the argument must be 5000
with a period of 1000000 I need a result of 500000 so the argument must be 5000
but with a 1Hz I got a duty cycle far shorter than 50%. Could it be the result of 500000 causes an overflow of the results?
but the argument of the width is typedef uint32_t pwmcnt_t; so I don't think it is an overflow
static PWMConfig pwmcfg = {
1000000, /* 1MHz PWM clock frequency. */
50, /* Initial PWM period . 50 is for 20kHz , 1000000 is for 1 Hz*/
NULL,//no callback
{PWM_OUTPUT_DISABLED, NULL},//CH 1
{PWM_OUTPUT_ACTIVE_HIGH, NULL},//CH 2
{PWM_OUTPUT_DISABLED, NULL},//CH 3
{PWM_OUTPUT_DISABLED, NULL}//CH 4
0,
0
from the example
pwmStart(&PWMD2, &pwmcfg);
pwmEnableChannel(&PWMD2, 1, PWM_PERCENTAGE_TO_WIDTH(&PWMD2, 5000));//DC 50%
enrico.dallavia
I think in my particular case of 50% fixed, I can use:
it seems to work with an oscilloscope
pwmEnableChannel(&PWMD2, 1, pwmcfg.period/2);
Even if pwmcnt_t is 32 bits, the timer is not necessarily 32 bits.
