Problems with STM32L-Discovery demo
360trev
Re: Problems with STM32L-Discovery demo
Post by 360trev »
PS. I do have an ST32F4-discovery eval board (STM32F407) which I could swap to if you think it may be the hardware. Haven't tried that yet.
When debug options are activated the OS halts the system in case of errors then it is possible to inspect the debug info using the ChibiOS Eclipse plugin.
Unfortunately I am unable to reproduce the problem here, I tested with two different STM32L-Discovery boards.
A similar demo is also available for the STM32F4-Discovery, you may give it a try but this would not tell us much because the F4 ADC driver is slightly different from the L1 one, we wouldn't know if there is a problem there.
CalebJames
Post by CalebJames »
Giovanni wrote:Another question, you wrote that the green LED goes ON and stops flashing, right? when this happens does the blue LED continue flashing?
Were you able to find an answer to this.. I am not able to work with these LED so what is the right way to do it..
No answer so it died there.
If you have specific questions better open a new topic.
CalebJames
CalebJames wrote:
Giovanni wrote:Another question, you wrote that the green led lights goes ON and stops flashing, right? when this happens does the blue LED continue flashing?
