HardFault and debug with messagebox
omcdr
Has thanked: 7 times
Re: HardFault and debug with messagebox
Post by omcdr »
I'm testing my code, sometimes I got HardFault, sometimes chSysHalt with reason
Details:0x8016ae0 <__func__.5691.lto_priv.256> "chSysUnlock"
Default:0x8016ae0 <__func__.5691.lto_priv.256> "chSysUnlock"
Decimal:134310624
Details:99 'c'
Will it be helpful in finding issue in my code ? Could you explain this reason ?
Probably you have a call to an I-class function and do not perform a reschedule before reaching chSysUnlock(), priorities are not in correct order thus the assertion, however I don't see this in the code you posted.
omcdr
Post by omcdr »
At this moment I'm testing simple thread with uart3 print. Uart3 is used in this thread only. I don't use I-class function.
Here is my test code, only one from 4 buff operation is active in test.
I got hardfault or pannic with sprintf function only, I have test another lite sprintf version like xsprintf with the same issue.
char buff[40] = "buf init                  \n\r";
void uart3Print(const char *string) {
   uartStartSend(&UARTD3, strlen(string), string);
void get_dec_str(uint8_t* str, size_t len, uint32_t val)
   uint8_t i;
   for (i = 1; i <= len; i++)
      str[len - i] = (uint8_t) ((val % 10UL) + '0');
      val /= 10;
THD_WORKING_AREA(waThreadDump, 256);
THD_FUNCTION(threadDump, arg)
   int x = 1, y = 2, z = 3;
   while (1)
      buff[9] = x++; //works
      get_dec_str(&buff[11], 3, x++); //works
      sprintf(buff, 15, "buf sprintf %d \n\r", x); //HardFault
      sprintf(buff, 38, "OUT: 1:%d 2:%d 3:%d\n\r", x, y, z); //panic
      uart3Print(buff);
      chThdSleepMilliseconds(5000);
You need to provide information about the system when the halt happens, stack traces would help.
omcdr
Post by omcdr »
Here is my stack trace
The problem happened before the call to uartStartSend() probably, try placing:
chSysLock();
chsysUnlock();
just before calling uartStartSend(), if I am right the assertion will be triggered in the unlock.
omcdr
Post by omcdr »
With code
   chSysLock();
   chSysUnlock();
I got Image
with
   chSysLock();
I got
and with code
   chSysLock();
   chSysUnlock();
Only the first one is relevant, it shows that the problem is not there, just detected there.
You must have an I-class function called somewhere in a thread (not ISR) not followed by a reschedule or a more hidden problem.
Are you IRQs initialized at correct priority levels? 0 and 1 are forbidden.
omcdr
Post by omcdr »
My IRQs have 3 and more priority levels.
I have only one thread.
This thread works, I have added delays.
char buff[40] = "buf start                 \n\r";
   int x = 1, y = 2, z = 3, v = 4, w = 5;
   while (1)
      uart3Print(buff);
      chThdSleepMilliseconds(500);
      sprintf(buff, "OUT: 1:%d 2:%d 3:%d 4:%d 5:%d\n\r", x++, y++, z, v, w);
      chThdSleepMilliseconds(1000);
If I start second thread with led blink
THD_WORKING_AREA(waThreadLed, 128);
THD_FUNCTION(threadLed, arg)
   while (1)
      LED1_ON;
      chThdSleepMilliseconds(10);
      LED1_OFF;
I got hardfault with call stack:
Which compiler are you using? those are completely random problems and I see nothing obvious in your code.
