Problem while using MPU6050
trunet
Re: Problem while using MPU6050
Post by trunet »
sapan wrote:As per datasheet, Sensitivity of sensor is 340 LSB/degree and output at 35 degree is -521. So your formula is,
Temperature (in Degree) = ( raw temperature output / 340) + offset
Where, offset = 35 + (521/340) = 36.5323
Thanks for your formula. I'll try later at home. Is 521 on offset formula right or it's -521?
offset = 35 + (-521/340) = 33.4677
sapan
Post by sapan »
Sorry for late reply. Offset is correct 36.5323. So your final equation is
Temperature = (raw output/340) + 36.5323.
Here when you put raw output = -521 you will get temperature = 35 degree
Let me know how accurate is temperature sensor of MPU.
