Supporting other prescaling factors in the PWM module
Moderator: tfAteba
Re: Supporting other prescaling factors in the PWM module
You may just post the modified files zipped, Theo can then do a compare.
orion
Has thanked: 4 times
Post by orion »
Sorry, forgot to make it compatible with patch. Below is the correct version.
pwm-modified.zip
modified files
(14.85 KiB) Downloaded 841 times
pwm_patch.zip
patch file
(5.56 KiB) Downloaded 867 times
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Post by tfAteba »
Thanks, i will then take a look tonigth.
tfAteba
Post by tfAteba »
Just a small message to tell you that I will take care of your work shortly. Sorry for the long delay due to my private situation.
tfAteba
Post by tfAteba »
Hello Orion,
One more time I want to apologize for the long delay.
Every things look good for me, I have tested the code and it work fine on the arduino Mega2560.
So the patch is committed on the trunk.
Thanks
