"chVTResetI(), #1" panic from i2c_lld_master_timeout
Re: "chVTResetI(), #1" panic from i2c_lld_master_timeout
In the morning my remaining neurons seem to work better, I found the other problem. Could you confirm this fixes it?
i2c_lld.zip
(5.67 KiB) Downloaded 439 times
lmamakos
Post by lmamakos »
Still fails at seemingly the same place when running the benchmark tests, but the panic is different..
port_halt () at ../../chibios/stable_2.4.x/os/ports/GCC/ARMCMx/chcore.c:48
48     port_disable();
(gdb) bt
#0  port_halt () at ../../chibios/stable_2.4.x/os/ports/GCC/ARMCMx/chcore.c:48
#1  0x08000d36 in chDbgPanic (msg=0x80122d8 "SV#6") at ../../chibios/stable_2.4.x/os/kernel/src/chdebug.c:274
#2  0x08000aea in dbg_check_lock_from_isr () at ../../chibios/stable_2.4.x/os/kernel/src/chdebug.c:141
#3  0x0800b536 in i2c_lld_safety_timeout (p=0x20001c14) at ../../chibios/stable_2.4.x/os/hal/platforms/STM32/i2c_lld.c:168
#4  0x080009f6 in chSysTimerHandlerI () at ../../chibios/stable_2.4.x/os/kernel/src/chsys.c:146
#5  0x080005a6 in SysTickVector () at ../../chibios/stable_2.4.x/os/ports/GCC/ARMCMx/chcore_v7m.c:52
#6  0xfffffffc in ?? ()
#7  0xfffffffc in ?? ()
(gdb) frame 2
141       chDbgPanic("SV#6");
(gdb) list
136    * @notapi
137    */
138   void dbg_check_lock_from_isr(void) {
139
140     if ((dbg_isr_cnt <= 0) || (dbg_lock_cnt != 0))
142     dbg_lock_cnt = 1;
143   }
144
145   /**
(gdb) p dbg_isr_cnt
$1 = 1
(gdb) p dbg_lock_cnt
$2 = 1
(gdb) up
168     chSysLockFromIsr();
(gdb) list
163    * @notapi
164    */
165   static void i2c_lld_safety_timeout(void *p) {
166     I2CDriver *i2cp = (I2CDriver *)p;
167
169     if (i2cp->thread) {
170       Thread *tp = i2cp->thread;
171       i2c_lld_abort_operation(i2cp);
172       i2cp->thread = NULL;
(gdb) p *i2cp
$3 = {state = I2C_ACTIVE_TX, config = 0x8015bf0, errors = 0, mutex = {m_queue = {p_next = 0x20001c20, p_prev = 0x20001c20}, m_owner = 0x20002690,
    m_next = 0x0}, thread = 0x0, addr = 59, dmamode = 4234, dmarx = 0x8014248, dmatx = 0x801423c, i2c = 0x40005400}
(gdb) up
146     chVTDoTickI();
(gdb) list
141       rlist.r_preempt--;
142   #endif
143   #if CH_DBG_THREADS_PROFILING
144     currp->p_time++;
145   #endif
146     chVTDoTickI();
147   #if defined(SYSTEM_TICK_EVENT_HOOK)
148     SYSTEM_TICK_EVENT_HOOK();
149   #endif
150   }
(gdb) up
52     chSysTimerHandlerI();
(gdb)
(gdb) p dbg_trace_buffer
$4 = {tb_size = 64, tb_ptr = 0x200012e4, tb_buffer = {{se_time = 30237, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30237,
      se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30237, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {
      se_time = 30237, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30237, se_tp = 0x20002690, se_wtobjp = 0x0,
      se_state = 0 '\000'}, {se_time = 30237, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {se_time = 30247, se_tp = 0x20002690,
      se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30247, se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30247,
      se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30247, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 2 '\002'}, {
      se_time = 30247, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30247, se_tp = 0x20000f28, se_wtobjp = 0x0,
      se_state = 6 '\006'}, {se_time = 30257, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30257, se_tp = 0x20000f28,
      se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30257, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30257,
      se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30257, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {
      se_time = 30257, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {se_time = 30267, se_tp = 0x20002690, se_wtobjp = 0x0,
      se_state = 0 '\000'}, {se_time = 30267, se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30267, se_tp = 0x20002690,
      se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30267, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30267,
      se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30267, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {
      se_time = 30277, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30277, se_tp = 0x20000f28, se_wtobjp = 0xffffffff,
      se_state = 2 '\002'}, {se_time = 30277, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30277, se_tp = 0x20000f28,
      se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30277, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30277,
      se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {se_time = 30287, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {
      se_time = 30287, se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30287, se_tp = 0x20002690, se_wtobjp = 0x0,
      se_state = 0 '\000'}, {se_time = 30287, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30287, se_tp = 0x20002690,
      se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30287, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {se_time = 30296,
      se_tp = 0x20000fe8, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30296, se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 6 '\006'}, {
      se_time = 30297, se_tp = 0x20000fe8, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30300, se_tp = 0x20002848, se_wtobjp = 0xffffffff,
      se_state = 0 '\000'}, {se_time = 30300, se_tp = 0x20002690, se_wtobjp = 0xffffffff, se_state = 6 '\006'}, {se_time = 30300, se_tp = 0x20000fe8,
      se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30197, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30197,
      se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {se_time = 30200, se_tp = 0x20002848, se_wtobjp = 0x0, se_state = 0 '\000'}, {
      se_time = 30200, se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 6 '\006'}, {se_time = 30207, se_tp = 0x20002690, se_wtobjp = 0x0,
      se_state = 0 '\000'}, {se_time = 30207, se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30207, se_tp = 0x20002690,
      se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30207, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30207,
      se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30207, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {
      se_time = 30217, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30217, se_tp = 0x20000f28, se_wtobjp = 0xffffffff,
      se_state = 2 '\002'}, {se_time = 30217, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30217, se_tp = 0x20000f28,
      se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30217, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30217,
      se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}, {se_time = 30227, se_tp = 0x20002690, se_wtobjp = 0x0, se_state = 0 '\000'}, {
      se_time = 30227, se_tp = 0x20000f28, se_wtobjp = 0xffffffff, se_state = 2 '\002'}, {se_time = 30227, se_tp = 0x20002690, se_wtobjp = 0x0,
      se_state = 0 '\000'}, {se_time = 30227, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 2 '\002'}, {se_time = 30227, se_tp = 0x20002690,
      se_wtobjp = 0x0, se_state = 0 '\000'}, {se_time = 30227, se_tp = 0x20000f28, se_wtobjp = 0x0, se_state = 6 '\006'}}}
(gdb)
For completeness, I'm using this compiler:
$ arm-none-eabi-gcc -v
Using built-in specs.
COLLECT_GCC=arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=/Users/louie/Documents/Bluetooth/tools/yagarto-4.6.2/bin/../libexec/gcc/arm-none-eabi/4.6.2/lto-wrapper
Target: arm-none-eabi
Configured with: ../gcc-4.6.2/configure --target=arm-none-eabi --prefix=/Users/mfischer/Projects/yagarto/install --disable-nls --disable-shared --disable-threads --with-gcc --with-gnu-ld --with-gnu-as --with-dwarf2 --enable-languages=c,c++ --enable-interwork --enable-multilib --with-newlib --with-headers=../newlib-1.19.0/newlib/libc/include --disable-libssp --disable-libstdcxx-pch --disable-libmudflap --disable-libgomp -v
Thread model: single
gcc version 4.6.2 (GCC)
and compiling with these options:
USE_OPT= -ggdb3 -fomit-frame-pointer
The file I sent is done for the version in trunk, you are using 2.4.x. There is an important difference, in the new version callbacks are not called within a lock. In 2.4.x the callback is invoked from within a lock. Sorry, it slipped from my mind.
You should remove chSysLockFromIsr() and chSysUnlockFromIsr() from the callback i2c_lld_safety_timeout(). The error you are getting is the state checker informing you about two consecutive locks.
Thanks for all the testing.
lmamakos
Post by lmamakos »
I removed the two lines as suggested, and I'm very happy to report that the problem I was seeing is gone. I'm pretty encouraged, since I could reliably reproduce the issue previously, and I've run through the same testing process 4 times now without a hint of the problem.
Thanks very much for looking at this, especially over the weekend. I know how difficult it can be to do this sort of debugging by "remote control."
You are welcome, really thanks for helping me in fixing this issue. The repository has been updated with the fix.
king2
Been thanked: 2 times
Post by king2 »
I met same problem.
When I2C timeout occurs, i2cp->state becomes I2C_LOCKED.
When I call I2C transfer next time, it rises exception, because I2C expects that state have to be I2C_READY.
Do you know workaroud for this (I cannot use TIME_INFINITE because I2C bus can have uncorrect state, and I have to reset it manually)?
Should I do stop/start i2c every time when I met timeout or you know better solution?
Thanks!
king2
Post by king2 »
And this is not a single problem.
I was tried to use my I2C STM8S driver, but met a problem - when I start to use OS hard (many threads and so on), I2C started to make some funny things, like marking START and STOP conditions at same time.
As I understand, this is happened because of OS frequently disables and enabled interrupts, so some bytes can be received before I2C interrupt, broking all statuses inside. Rising priority of IRQ helps a lot, but main problem is disabling IRQ in locked states. So, I cannot see some way to implement interrupt-driven I2C HAL driver.. :(
May be, I should write some code to make blocking I2C transfers?.. I don't know.. :(
The OS does not block interrupts for long time, probably it is the I2C peripheral that is "not optimal", even the STM32 I2C peripheral has similar issues, they finally revamped the I2C in the very latest STM32F0 devices.
My suggestion is to drop it and use a bit banged I2C implementation in the low level driver.
