Giovanni wrote:Consistency is always a good thing, reworking things not necessarily as good, especially if one is trying to close a release.
Understood, and agreed. Any idea on a time frame for release
Giovanni wrote:The stream will be enabled by the spiXXX() transfer call, what you can do is to change (or disable) the TX DMA trigger by changing the dmatx field of the SPIDriver structure, you can make the DMA be triggered by a timer instead of SPI or you may write the SPI DR register in the PWM callback.
I don't understand how they can be disabled, as a call is made to the DMA configuration macros which dereference the dmatx and dmarx pointers - so there is nothing safe to set them to. If you add a check for NULL, you can ignore the calls to the dma configuration macros. That would work and be the most flexible. How about that?
