Chibios thirdparty IRQ support
Re: Chibios thirdparty IRQ support
I would verify again IRQ priorities, including systick, inspect the NVIC registers in order to confirm.
It is possible to use the tickless mode, you need to provide the same timer interface like the HAL ST driver does. Note that the port can include an user header for this:
#if CH_CFG_ST_TIMEDELTA > 0
#if PORT_USE_ALT_TIMER == FALSE
#include "chcore_timer.h"
#else /* PORT_USE_ALT_TIMER != FALSE */
#include "chcore_timer_alt.h"
#endif /* PORT_USE_ALT_TIMER != FALSE */
#endif /* CH_CFG_ST_TIMEDELTA > 0 */
Put your implementation in a "chcore_timer_alt.h" and put -DPORT_USE_ALT_TIMER=1 in your Makefile. You can take the implemetation from hal_st_lld.c/.h.
rogtalha
Post by rogtalha »
Yes i checked the IRQ priorities.
Here are the results from gdb
a) SysTick_IRQn
0xe000ed23:     01000000 // Its at 4. Above PendSV and SVCall as suggested.
b) DMA1_Stream1_IRQn
(gdb) x/tb 0xe000e40c
0xe000e40c:     10000000   // Above Systick, at 8
c) USART3_IRQn
(gdb) x/tb 0xe000e427
0xe000e427:     10000000
Both USART and DMA IRQ's sit at 8, but still hog all the cpu time once turned on. I set a breakpoint at the SysTick exception handler entry, when the usart and dma irq's are turned on. The system never serves Systick. Am i missing some configuration macro or system setting?
Have you configured and enabled the SysTick, the system does not do that for you, it is done in HAL usually.
rogtalha
Post by rogtalha »
yup here is the code i am using for it.
void init()
    //Initializing the Systick Timer
    SysTick->LOAD = SYSTEM_CLOCK / CH_CFG_ST_FREQUENCY - (systime_t)1;
    NVIC_SetPriority(SysTick_IRQn,(1UL << __NVIC_PRIO_BITS) - 12UL);   //assuming __NVIC_PRIO_BITS=4
    SysTick->VAL = (uint32_t)0;
    SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk | SysTick_CTRL_ENABLE_Msk |
                  SysTick_CTRL_TICKINT_Msk;
Are you compiling with -O2? that could explain the missed breakpoint, try -O0.
