That warning has already been fixed in repository, it will be in next release. Note that it has no real impact.
undefined reference to ST2MS and MS2ST
Re: undefined reference to ST2MS and MS2ST
Thank you for that information and saving me yet again
when I use board files from 'os/hal/boards/ST_STM32F072B_DISCOVERY' if i just point BOARDSRC and BOARDINC to there we build fine however using our old files where we use PALConfig sample board file https://github.com/e11i0t23/qmk_firmwar ... _DISCOVERY it does not build due to Error: unknown type name 'PALConfig' however i have checked and this type can be seen from source in line 93 http://chibios.sourceforge.net/docs3/ha ... ource.html
Thanks again
ELliot
Thanks again
ELliot
e11i0t23 wrote:Thank you for that information and saving me yet again
Thanks again
ELliot
The link to the documentation you included was for a particular LLD implementation (perhaps it was even for the template?). Different low level drivers behave differently. As you are interested in the STM32F0xx, look at the platform file for which LLD it uses:
https://github.com/ChibiOS/ChibiOS/blob ... orm.mk#L33
As you can see, it uses GPIOv2. Looking at GPIOv2, you can see there is no such PALConfig struct there:
https://github.com/ChibiOS/ChibiOS/blob ... _pal_lld.h
The easiest way to avoid these problems is to use an existing board.cfg XML file for the same processor, customize it as needed, and generate the .c/.h files using the FTL processing script (fmpp). If you have any issues running the fmpp program and the such, you can just copy an existing .c/.h file from the same processor in a demo project, and just modify the .h file per your configuration. The .c file stays the same ..
Btw, if you're curious as to how to use the fmpp utility to generate the board.c/.h files from the command line - look at the example already provided in ChibiOS. All or most of the board files for the demos are generated by this tool:
https://github.com/ChibiOS/ChibiOS/blob ... nboards.sh
Sorry Giovanni for constantly linking to github, it's just faster to browse and find stuff there than sourceforge ... hint, hint ...
Thank you all again we have manged to update and test on a few boards now however with stm32f072 board we are trying to use as a test we are getting an error compiling a chibios fil
I assume that i am missing a define in chconf or halconf is this correct?
I am sorry if i am asking silly/noobish questions, i do make sure to try google, and try read through the code and demos first
Compiling: lib/chibios/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c In file included from ./lib/chibios/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.h:31:0,
from ./lib/chibios/os/hal/include/hal_st.h:46,
from ./lib/chibios/os/common/ports/ARMCMx/chcore_timer.h:32,
from ./lib/chibios/os/common/ports/ARMCMx/chcore.h:205,
from ./lib/chibios/os/rt/include/ch.h:110,
from ./lib/chibios/os/hal/osal/rt/osal.h:32,
from ./lib/chibios/os/hal/include/hal.h:28,
from lib/chibios/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:29:
lib/chibios/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c: In function 'rtc_lld_init':
./lib/chibios/os/hal/ports/STM32/STM32F0xx/stm32_registry.h:1695:45: error: 'STM32_IRQ_EXTI17_20_IRQ_PRIORITY' undeclared (first use in this function)
nvicEnableVector(STM32_RTC_COMMON_NUMBER, STM32_IRQ_EXTI17_20_IRQ_PRIORITY)
lib/chibios/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:591:3: note: in expansion of macro 'STM32_RTC_IRQ_ENABLE'
STM32_RTC_IRQ_ENABLE();
./lib/chibios/os/hal/ports/STM32/STM32F0xx/stm32_registry.h:1695:45: note: each undeclared identifier is reported only once for each function it appears in
STM32_RTC_IRQ_ENABLE();I assume that i am missing a define in chconf or halconf is this correct?
Found out i needed to add IRQ system settings to mcuconf now that is added the error is removed
Please make sure to take configuration files and makefiles from the version you are upgrading to.
Giovanni wrote:That warning has already been fixed in repository, it will be in next release. Note that it has no real impact.
Any idea when this will make it to the git repo as it is used as a sub-module? also is the
warning: initialization from incompatible pointer type
.end_cb = end_cb1,Re: undefined reference to ST2MS and MS2ST
Giovanni doesn't have anything to do with the Github mirror. The official ChibiOS repo is on sourceforge. Yeah, a lot of us don't like that, but it is what it is
Also, please post more information on that warning. Post the file, and more context from the compiler output .. Clearly, your callback declaration (end_cb1) does not match the one expected.
hi,
Some drivers has their callbacks changed, perhaps that is one of those cases. Please provide also surrounding code, it is hard to tell by just looking at that line.
The repository will stay on subversion, I am one of those simple minds unable to grasp the beauty of vast branching and multiple repositories glued by an xml.
