Something strange with timers
mabl
Re: Something strange with timers
Post by mabl »
<OT>
Hi king2,
what I've always been wondering: Why use such processors in the first place? Why not use parts which have free compilers and a strong community? Is it because of power and price consideration in mass products? But then, there are still AVRs in any size, aren't there? Or did some marketing/manager guy just decide: "You have to use it - period!"
</OT>
king2
Been thanked: 2 times
Post by king2 »
Processor selection was made because of its price, STM8S cheaper than any comparable AVR, for example it has 4 hardware PWMs.
Some time ago I have shifted from AVRs to STM8S for a-little-cheap-things and Cortex for more complex tasks.
But in this project compiler and MCU selection was made without respecting to my opinion, in fact, when I was started to rewrite this project they has boards already. So, I have not so much place to any movement here.. :(
I'm trying now to rewrite project to Raisonance compiler, tomorrow I will try to do this for Cosmic and hope that this will work:)
king2
Post by king2 »
Giovanni, thank you for trying to help me. If my tries to run my project under freeware versions of Cosmic or Raisonance will fail, I will try to port this on IAR again (or switch to atomthreads).
I'll give it a try in the weekend.
Anyway 8bit MCUs are starting to make no sense, there are Cortex-M0 devices at about the same price point. And Cortex processors make you save in other areas (peripherals, compilers, time and less trouble in general).
king2
Post by king2 »
I've changed my project to be compatible with Cosmic and tried to run it.
It works fine, so I think it is definitely IAR port issue.
What about MCU, I'm limited with existing design and devices that was made in hardware, so I have no choice.
For a little devices I prefer STM8S, at other side such MCUs (usually) do not needs OS. :)
Anyway, thank you, I'll be waiting for weekend and will try to modify IAR port by myself.
UPDATE: I have added some things to IAR port:
- added push for b8..b15 before and pop b8..b15 after switching stack (_port_switch assembler)
- added unsigned char vreg[8]; to start_ctx structure so it can be popped at first switch
At least on this time it is working a little bit better, but freezes anyway. It switches to empty area of memory, then to __iar_unhandled_exception();
I cannot catch where it brokes. Optimization is off.
So, few questions:
1. What do "popw x" in _port_thread_start?
2. Should I add something to _port_thread_start (pop/push, something else?)
3. How to catch it? Now it just jumps from unknown address to (random?) place and that's all..
You should post your chcore.h and chcore.c or it would be difficult to give any help.
king2
Post by king2 »
OK, I attached it here.
ISR asm listing follows:
   \                                 In section .near_func.text, align 1
    113          __interrupt void TIM2_OVR_UIF(void) {
   \                     TIM2_OVR_UIF:
   \                     _interrupt_15:
   \   000000 8A                    PUSH      CC
   \   000001 84                    POP       A
   \   000002 A4BF                  AND       A, #0xbf
   \   000004 88                    PUSH      A
   \   000005 86                    POP       CC
   \   000006 CD0000                CALL      L:?push_l0
   \   000009 CD0000                CALL      L:?push_l1
    114              CH_IRQ_PROLOGUE();
   \   00000C CD0000                CALL      L:dbg_check_enter_isr
    115              chSysLockFromIsr();
   \   00000F CD0000                CALL      L:dbg_check_lock_from_isr
    116              chSysTimerHandlerI();
   \   000012 CD0000                CALL      L:chSysTimerHandlerI
    117              chSysUnlockFromIsr();
   \   000015 CD0000                CALL      L:dbg_check_unlock_from_isr
    118              TIM2->SR1 = 0;
   \   000018 35005302              MOV       L:0x5302, #0x0
    119              CH_IRQ_EPILOGUE();
   \   00001C CD0000                CALL      L:dbg_check_leave_isr
   \   00001F CD0000                CALL      L:dbg_check_lock
   \   000022 CD0000                CALL      L:chSchIsPreemptionRequired
   \   000025 A100                  CP        A, #0x0
   \   000027 2703                  JREQ      L:??TIM2_OVR_UIF_0
   \   000029 CD0000                CALL      L:chSchDoReschedule
   \                     ??TIM2_OVR_UIF_0:
   \   00002C CD0000                CALL      L:dbg_check_unlock
    120          }
   \   00002F CD0000                CALL      L:?pop_l1
   \   000032 CD0000                CALL      L:?pop_l0
   \   000035 80                    IRET
    121
?l0 and ?l1 - first 8 bytes of virtual registers, i.e. ?b0..?b7.
chcore.zip
(5.57 KiB) Downloaded 482 times
king2
Post by king2 »
I have tried to debug application and found that IAR's compiler inside task functions call ?push_w4, that not simple pop'ed info from stack, it reads and writes stack directly, broking info in start_ctx structure.
After defining task functions with __task prefix (do not save and restore context in this function), all is working perfectly (for now :)).
Thank you for help!
I see some more issues in those files, I am going to make a revision but probably I will not be able to test it with the 8K limit.
I am hitting problems while compiling, most modules compile but I get this error:
Tool Internal Error:
Internal Error: [`anonymous-namespace'::Base::Validate]: Malformed instruction.
Error while running C/C++ Compiler
from chqueues.c and chsem.c. Not sure about the meaning of the above message.
