Page 2 of 4
Re: [RFC] Raspberry PI
Posted: Tue Jul 03, 2012 9:55 am
The USB appears to be the same OTG Synopsys peripheral used by the STM32F4 configured similarly to the OTG-HS, the required documentation is available from Synopsys. It is possible most of the STM32 code can be reused.
I must say that the "datasheet" I found sucks and I haven't found an header file for the peripheral definitions yet.
Posted: Tue Jul 03, 2012 1:40 pm
by utzig
> 2) The ARM11 should not be that different from the ARM9 which is already supported (I have to verify this point).
Hmmm, I will sound naive but I really didn't find the code! The os/ports/GCC/ARM only has ports for ARM7 processors. And I always supposed that for supporting ARM9 (or more modern) you would have to support MMU. Is that really available?
Here some documentation of the RB-PI GPU:
http://elinux.org/RPi_VideoCore_APIs
Linux has only high level drivers which are here:
https://github.com/raspberrypi/linux/bl ... m2708_fb.c
And communicate with low-level through a mailbox mechanism (bcm_mailbox_*) available here:
https://github.com/raspberrypi/linux/bl ... 708/vcio.c
Which are really communicating with the FW binary blobs available here (boot dir):
https://github.com/raspberrypi/firmware
A silly question. Isn't it possible to load a firmware blob (I'll suppose they are only a binaries) in any other OS? Are they Linux specific?
If there's any way of loading the blobs it would be possible to "reverse engineer" the mailbox mechanisms.
Fabio Utzig
Posted: Tue Jul 03, 2012 6:35 pm
The person who triggered this idea also has a lot of things already done:
https://github.com/dwelch67/raspberrypi
The above code could speed up the port considerably.
About the ROM code, if Linux can call it then probably it could be done also from ChibiOS, I assume that it is OS-independent code, the problem is the documentation, as usual.
About MMU, not all ARM9 devices have one and, even if present, we don't have to use it :-) (I think it would be bad for realtime performance anyway), the current ARM support is for ARM7 and ARM9, probably it would just have to be updated for ARM11.
Posted: Tue Jul 03, 2012 8:44 pm
by pjohnson
Don't let the naysayers dissuade you. I think that a RasberryPi Chibios port would be the coolest thing ever.
Posted: Wed Jul 04, 2012 11:32 am
by mobyfab
The Arm11 being an (obsolete) application processor, I don't really get the point of porting Chibios to it... except for the education and popularity point of view.
There are a few cheaper A8 based modules in preparation, based on the allwinner A10 or similar.
But still, this is an application processor, which would mostly run on Linux.
Posted: Thu Jul 12, 2012 7:25 pm
by Xamusk
I think the Raspberry would be a great platform if one wants an upgrade path when a faster processor is needed. Too bad it's too expensive (it costs more than $150 because of high shipping charges and duties), though it's still cheaper than some (most?) MCU platforms, when counting those too.
Posted: Mon Oct 15, 2012 4:03 pm
by Steve
I've ported ChibiOS/RT to the Raspberry Pi. The code is available on GitHub.
https://github.com/steve-bate/ChibiOS-RPi
There are currently Pi-specific device drivers for PAL, I2C, SPI, GPT, Serial. I've created a demo application using the shell and it runs the shell-based tests successfully. I've also created several examples of using Chibi to access Pi hardware (under testhal/BCM2835).
I'm curious about whether this is something that you'd want to integrate this with the Chibi SVN repository or if you'd prefer to keep the fork separated.
Steve
Posted: Mon Oct 15, 2012 6:21 pm
Hi Steve,
Good job, it was something I planned to do but never found time for it. I have some questions for you:
- Does it use the existing ARM port?
- Does it modify anything on the existing files or it is just an add-on over a ChibiOS version?
- On what ChibiOS/RT version has it been tested?
About including into the ChibiOS distribution, I am going to create a staging repository for this kind of contributions, probably it could go there immediately until it is ready and reviewed then it could go in the main distribution. I don't mind if you want to maintain it on your own repository too, I would still link it from the ChibiOS wiki with a dedicated page.
About the port, it would be interesting to write a mini guide about it or an how-to and place it on the wiki, do you already have something that could be adapted?
Posted: Mon Oct 15, 2012 6:34 pm
by Steve
Hello Giovanni,
Yes, it's based on the existing ARM port. It doesn't modify anything in the generic kernel or HAL code.
My current code was developed in a fork of mabl's git mirror, so it's sync'ed to SVN trunk frequently (2.5.1unstable).
I wrote a short "getting started" guide. It's available at http://www.stevebate.net/chibios-rpi/Ge ... arted.html . There's also some information on the GitHub repository's wiki pages.
Steve
Posted: Mon Oct 15, 2012 7:33 pm
I will have time to review the port during the next weekend then I will be able to give you some feedback. In the meanwhile I'll find a RPI :)
