encoding GPIO ports
wurstnase
Has thanked: 43 times
Been thanked: 30 times
Re: encoding GPIO ports
Post by wurstnase »
Giovanni wrote:Just a detail, you can map multiple event sources to the same eventmask_t bit. Your handler can then poll the various listeners for available flags. RAM usage is true.
I can't follow you with this completely. Do you have a minimal example, please?
It is "simple".
You can register multiple event sources to the same event bit calling chEvtRegisterMask() with "events" set to the same mask, when you get the event then you need to determine which source actually caused it, this is done by calling chEvtGetAndClearFlags() on each the event listener and see where there are flags to be "consumed".
