STM32G071 ADC calibration issue? Topic is solved
Dzarda
Has thanked: 7 times
Been thanked: 5 times
Re: STM32G071 ADC calibration issue?
Post by Dzarda »
Hi, I'm having probably the same issue on the L072. Happens in v20.3.3 and v21.6.1.
ADCv1/hal_adc_lld.c:
  /* Regulator enabled and stabilized before calibration.*/
  adc_lld_vreg_on(ADC1);
  ADC1->CR |= ADC_CR_ADCAL;
  while (ADC1->CR & ADC_CR_ADCAL) ///// Forever young
  ADC1->CR = 0;
  rccDisableADC1();
Peripheral while stuck:
Tried both STM32_ADC_CKMODE_PCLK_DIV4 and STM32_ADC_CKMODE_ADCCLK
I tested ADC initialization on an STM32L053 Nucleo board, it does not get stuck in there.
Do you have?
#define STM32_ADC_CLOCK_ENABLED             TRUE
#define STM32_ADC_ADC1_CKMODE               STM32_ADC_CKMODE_ADCCLK
What compiler are you using?
Dzarda
Post by Dzarda »
Thank you for the effort Giovanni,
Using GCC 9.3.1
I'm having trouble comprehending the behaviour. ADC clock is enabled but the ENR stays at zero...
I don't know, is it still zero while it is running in the loop?
You may try to change it from the debugger too.
Dzarda
Post by Dzarda »
I feel like a fool, it ADCEN is now set and calibration succeeds... No idea what fixed it. Now trying to backtrack.
Dzarda
Post by Dzarda »
Previous problem with ADCEN not turning on and CAL forever loop is not reproducible.
But had to switch clock from STM32_ADC_CKMODE_PCLK_DIV4 to STM32_ADC_CKMODE_ADCCLK in order to get samples.
Re-opening this topic because there is still the clock problem to be investigated, TBD.
bumping as self-reminder
not sure if this is still applicable, need to check
FXCoder
Has thanked: 188 times
Been thanked: 134 times
Post by FXCoder »
Anyone who had G0 ADC issues should now re-test with the latest from trunk.
Can anybody confirm if this can be closed with latest changes?
