Page 2 of 2
Re: STM32F767 freeze on chibios update
Posted: Sun Mar 08, 2020 1:11 pm
by tsm
Giovanni wrote:Those things are out of my visibility, can't really help with that.
My generic advice is to remove everything then re-introduce things one at time.
Thanks anyway. I'll try to keep this updated
Posted: Sun Mar 08, 2020 1:12 pm
by tsm
rew wrote:tsm wrote:- I'm compilling an extra file chibios/os/hal/ports/STM32/LLD/EXTIv1
- I had -mthumb mode enabled. I've restored this which entailed removing -mthumb and adding -mno-thumb-interwork -DTHUMB_NO_INTERWORKING. But still the same behaviour
If you need the "EXTIv1 driver", (or not) you seem to be using and STM32xxxx CPU. These are "cortex-M" arm-variants. These do not have the original ARM instruction set, but only the thumb instruction set.
So... I would expect that you NEED the -
mthumb option to the compiler.
Alright didn't know that, I'll keep them on
Posted: Sun Mar 08, 2020 5:44 pm
by tsm
The following doesn't work (micro seems to be "jammed") and debugger is always at ResetHandler. I've looked into the registers and GDB doesn't seem have read them by this point.
Nonetheless by moving
p1 outside of global scope (e.g. inside of
main)) everything works fine. This makes think of memory problems, but I have way to few experience on embedded to know where to look at or be sure. Any tip on how to use the map and elf file to understand if something's wrong?
// C++ headers.
#include <cstdio>
#include <ch.h>
#include <hal.h>
#include <SerialPort.hpp>
SerialPort p1 = SerialPort(&SD1);
int
main()
// Initialize subsystems.
palClearLine(LED_1);
palClearLine(LED_2);
palClearLine(LED_3);
while (!chThdShouldTerminateX())
chThdSleepMilliseconds(1000);
palToggleLine(LED_1);
palToggleLine(LED_2);
palToggleLine(LED_3);
Posted: Sun Mar 08, 2020 8:04 pm
Static constructors are invoked before main() is called.
Posted: Wed Mar 11, 2020 5:18 pm
by tsm
I think that constructor issue was caused by some bad linker options I changed when trying to debug. I've cleaned up the staging area, and started over with
chibios-ver19.1.3.
Now I'm back at the original error: the micro seems to stop before calling
chTMStartMeasurementX. I've switched on all the debug definitions, except for
CH_DBG_THREADS_PROFILING because I'm in tickless mode, and now while stepping with the debugger it goes to:
// chtrace.c @ line 143
void _trace_isr_leave(const char *isr) {
if ((ch.dbg.trace_buffer.suspended & CH_DBG_TRACE_MASK_ISR) == 0U) {
port_lock_from_isr();
ch.dbg.trace_buffer.ptr->type = CH_TRACE_TYPE_ISR_LEAVE;
ch.dbg.trace_buffer.ptr->state = 0U;
ch.dbg.trace_buffer.ptr->u.isr.name = isr;
trace_next();
port_unlock_from_isr();
and the panic message is
SV#4. According to the documentation this means: "The function chSysLock() has been called from an ISR or from within a critical zone. This can happen, for example, if you call chSysLock() twice.". Nonetheless I'm not able to figure out anything with it
Posted: Wed Mar 11, 2020 5:36 pm
by steved
If you're using static objects you need to update file \os\common\startup\ARMCMx\compilers\GCC\ld\rules_code.ld from the repository; or download it from a link in this thread:
viewtopic.php?p=37201
Posted: Sat Mar 14, 2020 7:11 pm
by tsm
Hi steved this solved the problem perfectly. I patched my local ver19.1.3 with the files at os/common/startup/ARMCMx/compilers/GCC/ and the problem got fixed.
Thank you both for helping!
