r13804 breaks C++ builds Topic is solved
stertingen
Has thanked: 7 times
Re: r13804 breaks C++ builds
Post by stertingen »
Giovanni wrote:Hi,
I removed the syscalls_cpp.* files (in trunk), now the wrapper includes the normal syscalls.c file. Could you retest the current wrapper? my demo is not failing but something could still be missing.
When using virtual functions in C++, __cxa_pure_virtual() is needed.
Thargon
Has thanked: 15 times
Been thanked: 24 times
Post by Thargon »
I finally found the time to update my project to the latest ChibiOS (21.11.x) and I'd like to thank you all for looking at the topic. Unfortunately though, I am having issues with the new stubs.
I get the following error message from ld:
Linking /home/thomas/work/AMiRo/AMiRo-OS/modules/DiWheelDrive_1-2/build/DiWheelDrive_1-2.elf
/home/thomas/Software/gcc-arm-embedded/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: /home/thomas/Software/gcc-arm-embedded/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp/libc.a(lib_a-signalr.o): in function `_kill_r':
signalr.c:(.text._kill_r+0x0): multiple definition of `_kill_r'; /home/thomas/work/AMiRo/AMiRo-OS/modules/DiWheelDrive_1-2/build/obj/syscalls.o (symbol from plugin):(.text+0x0): first defined here
However, I could resolve the issue by a small change to syscalls.c:
--- a/os/various/syscalls.c
+++ b/os/various/syscalls.c
@@ -193,11 +193,18 @@ void _exit(int status) {
-__attribute__((used))
-int _kill_r(struct _reent *r, int pid, int sig) {
-  (void) pid;
-  (void) sig;
-  __errno_r(r) = EINVAL;
-  return -1;
+__attribute__((used))
+int _kill(int pid, int sig) {
+  (void) pid;
+  (void) sig;
+  return -1;
I basically replaced the new _kill_r() function by the old _kill() method. I have no idea if this is an actual fix or rather a workaround. Maybe the issue with my project is something entirely different (but I have no clue what that could be).
Any comments/help appreciated!
- Thomas
Fixed both issues in 20.3, 21.11 and trunk.
Thanks for finding.
