Re: STM32G473 test fail
Posted: Fri Jun 25, 2021 4:04 pm
alexblack wrote:I sequently checked last revisions of the SVN Repositiry and was found that last working revision is 14324 of trunk branch.
This helps for sure, thanks.
ChibiOS - Copyright (C) 2006..2020 Giovanni Di Sirio
* @file rt/templates/chconf.h
* @brief Configuration file template.
* @details A copy of this file must be placed in each project directory, it
* contains the application specific kernel settings.
* @addtogroup config
* @details Kernel related settings and hooks.
#ifndef CHCONF_H
#define CHCONF_H
#define _CHIBIOS_RT_CONF_
#define _CHIBIOS_RT_CONF_VER_7_0_
* @name System settings
* @brief Handling of instances.
* @note If enabled then threads assigned to various instances can
* interact each other using the same synchronization objects.
* If disabled then each OS instance is a separate world, no
* direct interactions are handled by the OS.
#if !defined(CH_CFG_SMP_MODE)
#define CH_CFG_SMP_MODE FALSE
* @name System timers settings
* @brief System time counter resolution.
* @note Allowed values are 16, 32 or 64 bits.
#if !defined(CH_CFG_ST_RESOLUTION)
#define CH_CFG_ST_RESOLUTION 32
* @brief System tick frequency.
* @details Frequency of the system timer that drives the system ticks. This
* setting also defines the system tick time unit.
#if !defined(CH_CFG_ST_FREQUENCY)
#define CH_CFG_ST_FREQUENCY 10000
* @brief Time intervals data size.
#if !defined(CH_CFG_INTERVALS_SIZE)
#define CH_CFG_INTERVALS_SIZE 32
* @brief Time types data size.
* @note Allowed values are 16 or 32 bits.
#if !defined(CH_CFG_TIME_TYPES_SIZE)
#define CH_CFG_TIME_TYPES_SIZE 32
* @brief Time delta constant for the tick-less mode.
* @note If this value is zero then the system uses the classic
* periodic tick. This value represents the minimum number
* of ticks that is safe to specify in a timeout directive.
* The value one is not valid, timeouts are rounded up to
* this value.
#if !defined(CH_CFG_ST_TIMEDELTA)
#define CH_CFG_ST_TIMEDELTA 2
* @name Kernel parameters and options
* @brief Round robin interval.
* @details This constant is the number of system ticks allowed for the
* threads before preemption occurs. Setting this value to zero
* disables the preemption for threads with equal priority and the
* round robin becomes cooperative. Note that higher priority
* threads can still preempt, the kernel is always preemptive.
* @note Disabling the round robin preemption makes the kernel more compact
* and generally faster.
* @note The round robin preemption is not supported in tickless mode and
* must be set to zero in that case.
#if !defined(CH_CFG_TIME_QUANTUM)
#define CH_CFG_TIME_QUANTUM 0
* @brief Idle thread automatic spawn suppression.
* @details When this option is activated the function @p chSysInit()
* does not spawn the idle thread. The application @p main()
* function becomes the idle thread and must implement an
* infinite loop.
#if !defined(CH_CFG_NO_IDLE_THREAD)
#define CH_CFG_NO_IDLE_THREAD FALSE
* @name Performance options
* @brief OS optimization.
* @details If enabled then time efficient rather than space efficient code
* is used when two possible implementations exist.
* @note This is not related to the compiler optimization options.
* @note The default is @p TRUE.
#if !defined(CH_CFG_OPTIMIZE_SPEED)
#define CH_CFG_OPTIMIZE_SPEED TRUE
* @name Subsystem options
* @brief Time Measurement APIs.
* @details If enabled then the time measurement APIs are included in
* the kernel.
#if !defined(CH_CFG_USE_TM)
#define CH_CFG_USE_TM FALSE
* @brief Time Stamps APIs.
* @details If enabled then the time time stamps APIs are included in
* the kernel.
#if !defined(CH_CFG_USE_TIMESTAMP)
#define CH_CFG_USE_TIMESTAMP TRUE
* @brief Threads registry APIs.
* @details If enabled then the registry APIs are included in the kernel.
#if !defined(CH_CFG_USE_REGISTRY)
#define CH_CFG_USE_REGISTRY TRUE
* @brief Threads synchronization APIs.
* @details If enabled then the @p chThdWait() function is included in
* the kernel.
#if !defined(CH_CFG_USE_WAITEXIT)
#define CH_CFG_USE_WAITEXIT TRUE
* @brief Semaphores APIs.
* @details If enabled then the Semaphores APIs are included in the kernel.
#if !defined(CH_CFG_USE_SEMAPHORES)
#define CH_CFG_USE_SEMAPHORES TRUE
* @brief Semaphores queuing mode.
* @details If enabled then the threads are enqueued on semaphores by
* priority rather than in FIFO order.
* @note The default is @p FALSE. Enable this if you have special
* requirements.
* @note Requires @p CH_CFG_USE_SEMAPHORES.
#if !defined(CH_CFG_USE_SEMAPHORES_PRIORITY)
#define CH_CFG_USE_SEMAPHORES_PRIORITY FALSE
* @brief Mutexes APIs.
* @details If enabled then the mutexes APIs are included in the kernel.
#if !defined(CH_CFG_USE_MUTEXES)
#define CH_CFG_USE_MUTEXES FALSE
* @brief Enables recursive behavior on mutexes.
* @note Recursive mutexes are heavier and have an increased
* memory footprint.
* @note Requires @p CH_CFG_USE_MUTEXES.
#if !defined(CH_CFG_USE_MUTEXES_RECURSIVE)
#define CH_CFG_USE_MUTEXES_RECURSIVE FALSE
* @brief Conditional Variables APIs.
* @details If enabled then the conditional variables APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_CONDVARS)
#define CH_CFG_USE_CONDVARS FALSE
* @brief Conditional Variables APIs with timeout.
* @details If enabled then the conditional variables APIs with timeout
* specification are included in the kernel.
* @note Requires @p CH_CFG_USE_CONDVARS.
#if !defined(CH_CFG_USE_CONDVARS_TIMEOUT)
#define CH_CFG_USE_CONDVARS_TIMEOUT FALSE
* @brief Events Flags APIs.
* @details If enabled then the event flags APIs are included in the kernel.
#if !defined(CH_CFG_USE_EVENTS)
#define CH_CFG_USE_EVENTS TRUE
* @brief Events Flags APIs with timeout.
* @details If enabled then the events APIs with timeout specification
* are included in the kernel.
* @note Requires @p CH_CFG_USE_EVENTS.
#if !defined(CH_CFG_USE_EVENTS_TIMEOUT)
#define CH_CFG_USE_EVENTS_TIMEOUT TRUE
* @brief Synchronous Messages APIs.
* @details If enabled then the synchronous messages APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_MESSAGES)
#define CH_CFG_USE_MESSAGES TRUE
* @brief Synchronous Messages queuing mode.
* @details If enabled then messages are served by priority rather than in
* FIFO order.
* requirements.
* @note Requires @p CH_CFG_USE_MESSAGES.
#if !defined(CH_CFG_USE_MESSAGES_PRIORITY)
#define CH_CFG_USE_MESSAGES_PRIORITY FALSE
* @brief Dynamic Threads APIs.
* @details If enabled then the dynamic threads creation APIs are included
* in the kernel.
* @note Requires @p CH_CFG_USE_WAITEXIT.
* @note Requires @p CH_CFG_USE_HEAP and/or @p CH_CFG_USE_MEMPOOLS.
#if !defined(CH_CFG_USE_DYNAMIC)
#define CH_CFG_USE_DYNAMIC FALSE
* @name OSLIB options
* @brief Mailboxes APIs.
* @details If enabled then the asynchronous messages (mailboxes) APIs are
* included in the kernel.
#if !defined(CH_CFG_USE_MAILBOXES)
#define CH_CFG_USE_MAILBOXES FALSE
* @brief Core Memory Manager APIs.
* @details If enabled then the core memory manager APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_MEMCORE)
#define CH_CFG_USE_MEMCORE FALSE
* @brief Managed RAM size.
* @details Size of the RAM area to be managed by the OS. If set to zero
* then the whole available RAM is used. The core memory is made
* available to the heap allocator and/or can be used directly through
* the simplified core memory allocator.
* @note In order to let the OS manage the whole RAM the linker script must
* provide the @p __heap_base__ and @p __heap_end__ symbols.
* @note Requires @p CH_CFG_USE_MEMCORE.
#if !defined(CH_CFG_MEMCORE_SIZE)
#define CH_CFG_MEMCORE_SIZE 0
* @brief Heap Allocator APIs.
* @details If enabled then the memory heap allocator APIs are included
* in the kernel.
* @note Requires @p CH_CFG_USE_MEMCORE and either @p CH_CFG_USE_MUTEXES or
* @p CH_CFG_USE_SEMAPHORES.
* @note Mutexes are recommended.
#if !defined(CH_CFG_USE_HEAP)
#define CH_CFG_USE_HEAP FALSE
* @brief Memory Pools Allocator APIs.
* @details If enabled then the memory pools allocator APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_MEMPOOLS)
#define CH_CFG_USE_MEMPOOLS FALSE
* @brief Objects FIFOs APIs.
* @details If enabled then the objects FIFOs APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_OBJ_FIFOS)
#define CH_CFG_USE_OBJ_FIFOS FALSE
* @brief Pipes APIs.
* @details If enabled then the pipes APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_PIPES)
#define CH_CFG_USE_PIPES FALSE
* @brief Objects Caches APIs.
* @details If enabled then the objects caches APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_OBJ_CACHES)
#define CH_CFG_USE_OBJ_CACHES FALSE
* @brief Delegate threads APIs.
* @details If enabled then the delegate threads APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_DELEGATES)
#define CH_CFG_USE_DELEGATES FALSE
* @brief Jobs Queues APIs.
* @details If enabled then the jobs queues APIs are included
* in the kernel.
#if !defined(CH_CFG_USE_JOBS)
#define CH_CFG_USE_JOBS FALSE
* @name Objects factory options
* @brief Objects Factory APIs.
* @details If enabled then the objects factory APIs are included in the
* kernel.
#if !defined(CH_CFG_USE_FACTORY)
#define CH_CFG_USE_FACTORY FALSE
* @brief Maximum length for object names.
* @details If the specified length is zero then the name is stored by
* pointer but this could have unintended side effects.
#if !defined(CH_CFG_FACTORY_MAX_NAMES_LENGTH)
#define CH_CFG_FACTORY_MAX_NAMES_LENGTH 8
* @brief Enables the registry of generic objects.
#if !defined(CH_CFG_FACTORY_OBJECTS_REGISTRY)
#define CH_CFG_FACTORY_OBJECTS_REGISTRY TRUE
* @brief Enables factory for generic buffers.
#if !defined(CH_CFG_FACTORY_GENERIC_BUFFERS)
#define CH_CFG_FACTORY_GENERIC_BUFFERS TRUE
* @brief Enables factory for semaphores.
#if !defined(CH_CFG_FACTORY_SEMAPHORES)
#define CH_CFG_FACTORY_SEMAPHORES TRUE
* @brief Enables factory for mailboxes.
#if !defined(CH_CFG_FACTORY_MAILBOXES)
#define CH_CFG_FACTORY_MAILBOXES FALSE
* @brief Enables factory for objects FIFOs.
#if !defined(CH_CFG_FACTORY_OBJ_FIFOS)
#define CH_CFG_FACTORY_OBJ_FIFOS TRUE
* @brief Enables factory for Pipes.
#if !defined(CH_CFG_FACTORY_PIPES) || defined(__DOXYGEN__)
#define CH_CFG_FACTORY_PIPES TRUE
* @name Debug options
* @brief Debug option, kernel statistics.
#if !defined(CH_DBG_STATISTICS)
#define CH_DBG_STATISTICS FALSE
* @brief Debug option, system state check.
* @details If enabled the correct call protocol for system APIs is checked
* at runtime.
#if !defined(CH_DBG_SYSTEM_STATE_CHECK)
#define CH_DBG_SYSTEM_STATE_CHECK TRUE
* @brief Debug option, parameters checks.
* @details If enabled then the checks on the API functions input
* parameters are activated.
#if !defined(CH_DBG_ENABLE_CHECKS)
#define CH_DBG_ENABLE_CHECKS TRUE
* @brief Debug option, consistency checks.
* @details If enabled then all the assertions in the kernel code are
* activated. This includes consistency checks inside the kernel,
* runtime anomalies and port-defined checks.
#if !defined(CH_DBG_ENABLE_ASSERTS)
#define CH_DBG_ENABLE_ASSERTS TRUE
* @brief Debug option, trace buffer.
* @details If enabled then the trace buffer is activated.
* @note The default is @p CH_DBG_TRACE_MASK_DISABLED.
#if !defined(CH_DBG_TRACE_MASK)
#define CH_DBG_TRACE_MASK CH_DBG_TRACE_MASK_DISABLED
* @brief Trace buffer entries.
* @note The trace buffer is only allocated if @p CH_DBG_TRACE_MASK is
* different from @p CH_DBG_TRACE_MASK_DISABLED.
#if !defined(CH_DBG_TRACE_BUFFER_SIZE)
#define CH_DBG_TRACE_BUFFER_SIZE 128
* @brief Debug option, stack checks.
* @details If enabled then a runtime stack check is performed.
* @note The stack check is performed in a architecture/port dependent way.
* It may not be implemented or some ports.
* @note The default failure mode is to halt the system with the global
* @p panic_msg variable set to @p NULL.
#if !defined(CH_DBG_ENABLE_STACK_CHECK)
#define CH_DBG_ENABLE_STACK_CHECK TRUE
* @brief Debug option, stacks initialization.
* @details If enabled then the threads working area is filled with a byte
* value when a thread is created. This can be useful for the
* runtime measurement of the used stack.
#if !defined(CH_DBG_FILL_THREADS)
#define CH_DBG_FILL_THREADS TRUE
* @brief Debug option, threads profiling.
* @details If enabled then a field is added to the @p thread_t structure that
* counts the system ticks occurred while executing the thread.
* @note This debug option is not currently compatible with the
* tickless mode.
#if !defined(CH_DBG_THREADS_PROFILING)
#define CH_DBG_THREADS_PROFILING FALSE
* @name Kernel hooks
* @brief System structure extension.
* @details User fields added to the end of the @p ch_system_t structure.
#define CH_CFG_SYSTEM_EXTRA_FIELDS \
/* Add system custom fields here.*/
* @brief System initialization hook.
* @details User initialization code added to the @p chSysInit() function
* just before interrupts are enabled globally.
#define CH_CFG_SYSTEM_INIT_HOOK() { \
/* Add system initialization code here.*/ \
* @brief OS instance structure extension.
* @details User fields added to the end of the @p os_instance_t structure.
#define CH_CFG_OS_INSTANCE_EXTRA_FIELDS \
/* Add OS instance custom fields here.*/
* @brief OS instance initialization hook.
* @param[in] oip pointer to the @p os_instance_t structure
#define CH_CFG_OS_INSTANCE_INIT_HOOK(oip) { \
/* Add OS instance initialization code here.*/ \
* @brief Threads descriptor structure extension.
* @details User fields added to the end of the @p thread_t structure.
#define CH_CFG_THREAD_EXTRA_FIELDS \
/* Add threads custom fields here.*/
* @brief Threads initialization hook.
* @details User initialization code added to the @p _thread_init() function.
* @note It is invoked from within @p _thread_init() and implicitly from all
* the threads creation APIs.
* @param[in] tp pointer to the @p thread_t structure
#define CH_CFG_THREAD_INIT_HOOK(tp) { \
/* Add threads initialization code here.*/ \
* @brief Threads finalization hook.
* @details User finalization code added to the @p chThdExit() API.
#define CH_CFG_THREAD_EXIT_HOOK(tp) { \
/* Add threads finalization code here.*/ \
* @brief Context switch hook.
* @details This hook is invoked just before switching between threads.
* @param[in] ntp thread being switched in
* @param[in] otp thread being switched out
#define CH_CFG_CONTEXT_SWITCH_HOOK(ntp, otp) { \
/* Context switch code here.*/ \
* @brief ISR enter hook.
#define CH_CFG_IRQ_PROLOGUE_HOOK() { \
/* IRQ prologue code here.*/ \
* @brief ISR exit hook.
#define CH_CFG_IRQ_EPILOGUE_HOOK() { \
/* IRQ epilogue code here.*/ \
* @brief Idle thread enter hook.
* @note This hook is invoked within a critical zone, no OS functions
* should be invoked from here.
* @note This macro can be used to activate a power saving mode.
#define CH_CFG_IDLE_ENTER_HOOK() { \
/* Idle-enter code here.*/ \
* @brief Idle thread leave hook.
* @note This macro can be used to deactivate a power saving mode.
#define CH_CFG_IDLE_LEAVE_HOOK() { \
/* Idle-leave code here.*/ \
* @brief Idle Loop hook.
* @details This hook is continuously invoked by the idle thread loop.
#define CH_CFG_IDLE_LOOP_HOOK() { \
/* Idle loop code here.*/ \
* @brief System tick event hook.
* @details This hook is invoked in the system tick handler immediately
* after processing the virtual timers queue.
#define CH_CFG_SYSTEM_TICK_HOOK() { \
/* System tick event code here.*/ \
* @brief System halt hook.
* @details This hook is invoked in case to a system halting error before
* the system is halted.
#define CH_CFG_SYSTEM_HALT_HOOK(reason) { \
/* System halt code here.*/ \
* @brief Trace hook.
* @details This hook is invoked each time a new record is written in the
* trace buffer.
#define CH_CFG_TRACE_HOOK(tep) { \
/* Trace code here.*/ \
* @brief Runtime Faults Collection Unit hook.
* @details This hook is invoked each time new faults are collected and stored.
#define CH_CFG_RUNTIME_FAULTS_HOOK(mask) { \
/* Faults handling code here.*/ \
/* Port-specific settings (override port settings defaulted in chcore.h). */
#endif /* CHCONF_H */
