Hi Giovanni/Faisal,
Issue is, these elements(GPIOI) are not defined in board.chcfg file. We can manually add this node, but wanted to know if there is a tool available to generate these chcfg files. How did you generate them in the first place?
Thanks,
AQ
#1198 breaks compilation for all STM496 with less than 169 pins Topic is solved
- sabdulqadir
- Has thanked: 13 times
- Been thanked: 4 times
Re: #1198 breaks compilation for all STM496 with less than 169 pins
sabdulqadir wrote:Hi Giovanni/Faisal,
Thanks,
AQ
Many tools out there can do this apparently:
https://stackoverflow.com/questions/171 ... dtd-or-xsd
Just tried the tool that comes with Visual Studio (not VSCode). Below is what it generated. Here is the guide I used: https://www.vishalon.net/blog/generate- ... ual-studio .
I just noticed by doing this exercise, that you can define certain headers to be present in the generated .c file, as well as an __early_init and boardInit functions ..
Regads.
Regads.
<?xml version="1.0" encoding="utf-8"?>
<board>
<configuration_settings>
<templates_path>templates_path1</templates_path>
<output_path>output_path1</output_path>
<board_files_path>board_files_path1</board_files_path>
<hal_version>5.0.x</hal_version>
</configuration_settings>
<board_name>board_name1</board_name>
<board_id>board_id1</board_id>
<board_functions>
<__early_init>__early_init1</__early_init>
<boardInit>boardInit1</boardInit>
<sdc_lld_is_card_inserted>sdc_lld_is_card_inserted1</sdc_lld_is_card_inserted>
<sdc_lld_is_write_protected>sdc_lld_is_write_protected1</sdc_lld_is_write_protected>
<mmc_lld_is_card_inserted>mmc_lld_is_card_inserted1</mmc_lld_is_card_inserted>
<mmc_lld_is_write_protected>mmc_lld_is_write_protected1</mmc_lld_is_write_protected>
</board_functions>
<headers>
<header>header1</header>
<header>header2</header>
<header>header3</header>
</headers>
<ethernet_phy>
<identifier>identifier1</identifier>
<bus_type>RMII</bus_type>
</ethernet_phy>
<usb_phy>
<bus_type>Integrated</bus_type>
</usb_phy>
<subtype>STM32L432xx</subtype>
<clocks HSEBypass="false" HSEFrequency="0" LSEBypass="false" LSEDrive="3 High Drive (default)" LSEFrequency="0" VDD="180" />
<ports>
<GPIOA>
<pin0 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin1 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin2 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin3 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin4 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin5 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin6 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin7 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin8 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin9 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin10 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin11 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin12 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin13 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin14 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin15 ID="ID1" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="Floating" Alternate="0" AnalogSwitch="Disabled" PinLock="Disabled" />
</GPIOA>
<GPIOB>
<pin0 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin1 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin2 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin3 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin4 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin5 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin6 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin7 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin8 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin9 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin10 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin11 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin12 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin13 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin14 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin15 ID="ID2" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullUp" Alternate="15" AnalogSwitch="Enabled" PinLock="Enabled" />
</GPIOB>
<GPIOC>
<pin0 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin1 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin2 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin3 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin4 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin5 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin6 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin7 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin8 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin9 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin10 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin11 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin12 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin13 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin14 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin15 ID="ID3" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="PullDown" Alternate="1" AnalogSwitch="Disabled" PinLock="Disabled" />
</GPIOC>
<GPIOD>
<pin0 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin1 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin2 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin3 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin4 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin5 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin6 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin7 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin8 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin9 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin10 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin11 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin12 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin13 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin14 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin15 ID="ID4" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="Floating" Alternate="14" AnalogSwitch="Enabled" PinLock="Enabled" />
</GPIOD>
<GPIOE>
<pin0 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin1 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin2 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin3 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin4 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin5 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin6 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin7 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin8 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin9 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin10 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin11 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin12 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin13 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin14 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin15 ID="ID5" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullUp" Alternate="2" AnalogSwitch="Disabled" PinLock="Disabled" />
</GPIOE>
<GPIOF>
<pin0 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin1 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin2 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin3 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin4 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin5 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin6 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin7 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin8 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin9 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin10 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin11 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin12 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin13 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin14 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin15 ID="ID6" Mode="Input" Level="Low" Speed="Low" Type="OpenDrain" Resistor="PullDown" Alternate="13" AnalogSwitch="Enabled" PinLock="Enabled" />
</GPIOF>
<GPIOG>
<pin0 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin1 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin2 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin3 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin4 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin5 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin6 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin7 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin8 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin9 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin10 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin11 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin12 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin13 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin14 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin15 ID="ID7" Mode="Output" Level="High" Speed="High" Type="PushPull" Resistor="Floating" Alternate="3" AnalogSwitch="Disabled" PinLock="Disabled" />
</GPIOG>
<GPIOH>
<pin0 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin1 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin2 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin3 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin4 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin5 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin6 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin7 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin8 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin9 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin10 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin11 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin12 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin13 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin14 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
<pin15 ID="ID8" Mode="Alternate" Level="Low" Speed="Maximum" Type="OpenDrain" Resistor="PullUp" Alternate="12" AnalogSwitch="Enabled" PinLock="Enabled" />
</GPIOH>
<GPIOI>
<pin0 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin1 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin2 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin3 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin4 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin5 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin6 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin7 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin8 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin9 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin10 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin11 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin12 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin13 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin14 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
<pin15 ID="ID9" Mode="Analog" Level="High" Speed="Minimum" Type="PushPull" Resistor="PullDown" Alternate="4" AnalogSwitch="Disabled" PinLock="Disabled" />
</GPIOI>
</ports>
</board>
Thanks,
AQ
Sorry, I missed this question, there are two ways:
- Using ChibiStudio: File->new->other->chibios->chibios_configuration_wizard
- Getting a template from under /tools/ftl/xml then renaming it to .chcfg
