Page 2 of 2
Re: STM32G071 ADC resolution is always 12 bits
Posted: Wed Mar 02, 2022 8:57 am
psyco wrote:This appears to be an errata. See ES0418 2.6.2, "Writing ADC_CFGR1 register while ADEN bit is set resets RES[1:0] bitfield".
This must be it, moving this topic into the "bug reports" section. This could be an ugly fix if we have to stop the ADC each time we program a conversion...
Posted: Tue Mar 15, 2022 11:28 am
Could you give a try to the following change?
    ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
 * @file    ADCv1/hal_adc_lld.c
 * @brief   STM32 ADC subsystem low level driver source.
 * @addtogroup ADC
#include "hal.h"
#if HAL_USE_ADC || defined(__DOXYGEN__)
/* Driver local definitions.                                                 */
#define ADC1_DMA_CHANNEL                                                    \
  STM32_DMA_GETCHANNEL(STM32_ADC_ADC1_DMA_STREAM, STM32_ADC1_DMA_CHN)
/* Driver exported variables.                                                */
/** @brief ADC1 driver identifier.*/
#if STM32_ADC_USE_ADC1 || defined(__DOXYGEN__)
ADCDriver ADCD1;
/* Driver local variables and types.                                         */
/* Driver local functions.                                                   */
 * @brief   ADC voltage regulator enable.
 * @param[in] adc       pointer to the ADC registers block
NOINLINE static void adc_lld_vreg_on(ADC_TypeDef *adc) {
  osalDbgAssert(adc->CR == 0, "invalid register state");
#if defined(ADC_CR_ADVREGEN)
  adc->CR = ADC_CR_ADVREGEN;
  volatile uint32_t loop = (STM32_HCLK >> 20) << 4;
  do {
    loop--;
  } while (loop > 0);
#else
 * @brief   Starts the ADC enable procedure.
static void adc_lld_start_enable_adc(ADC_TypeDef *adc) {
  adc->CR = ADC_CR_ADEN;
 * @brief   Waits for the ADC enable procedure completion.
static void adc_lld_wait_enable_adc(ADC_TypeDef *adc) {
  while ((adc->ISR & ADC_ISR_ADRDY) == 0U) {
    /* Waiting for ADC to be stable.*/
 * @brief   Stops an ongoing conversion, if any.
static void adc_lld_stop_adc(ADC_TypeDef *adc) {
  if (adc->CR & ADC_CR_ADSTART) {
    adc->CR |= ADC_CR_ADSTP;
    while (adc->CR & ADC_CR_ADSTP)
    adc->IER = 0;
  /* Disabling the ADC.*/
  adc->CR |= ADC_CR_ADDIS;
  while ((adc->CR & ADC_CR_ADDIS) != 0U) {
    /* Waiting for ADC to be disabled.*/
 * @brief   ADC DMA service routine.
 * @param[in] adcp      pointer to the @p ADCDriver object
 * @param[in] flags     pre-shifted content of the ISR register
static void adc_lld_serve_rx_interrupt(ADCDriver *adcp, uint32_t flags) {
  /* DMA errors handling.*/
  if ((flags & (STM32_DMA_ISR_TEIF | STM32_DMA_ISR_DMEIF)) != 0) {
    /* DMA, this could help only if the DMA tries to access an unmapped
       address space or violates alignment rules.*/
    _adc_isr_error_code(adcp, ADC_ERR_DMAFAILURE);
  else {
    /* It is possible that the conversion group has already be reset by the
       ADC error handler, in this case this interrupt is spurious.*/
    if (adcp->grpp != NULL) {
      if ((flags & STM32_DMA_ISR_TCIF) != 0) {
        /* Transfer complete processing.*/
        _adc_isr_full_code(adcp);
      else if ((flags & STM32_DMA_ISR_HTIF) != 0) {
        /* Half transfer processing.*/
        _adc_isr_half_code(adcp);
/* Driver interrupt handlers.                                                */
#if !defined(STM32_ADC1_HANDLER)
#error "STM32_ADC1_HANDLER not defined"
 * @brief   ADC interrupt handler.
 * @isr
OSAL_IRQ_HANDLER(STM32_ADC1_HANDLER) {
  OSAL_IRQ_PROLOGUE();
  adc_lld_serve_interrupt(&ADCD1);
#if defined(STM32_ADC_ADC1_IRQ_HOOK)
  OSAL_IRQ_EPILOGUE();
/* Driver exported functions.                                                */
 * @brief   Low level ADC driver initialization.
 * @notapi
void adc_lld_init(void) {
  /* Driver initialization.*/
  adcObjectInit(&ADCD1);
  ADCD1.adc     = ADC1;
  ADCD1.dmastp  = NULL;
  ADCD1.dmamode = STM32_DMA_CR_CHSEL(ADC1_DMA_CHANNEL) |
                  STM32_DMA_CR_PL(STM32_ADC_ADC1_DMA_PRIORITY) |
                  STM32_DMA_CR_DIR_P2M |
                  STM32_DMA_CR_MSIZE_HWORD | STM32_DMA_CR_PSIZE_HWORD |
                  STM32_DMA_CR_MINC        | STM32_DMA_CR_TCIE        |
                  STM32_DMA_CR_DMEIE       | STM32_DMA_CR_TEIE;
  /* The vector is initialized on driver initialization and never
     disabled.*/
  nvicEnableVector(12, STM32_ADC_ADC1_IRQ_PRIORITY);
  /* Calibration procedure.*/
  rccEnableADC1(true);
  /* CCR setup.*/
  ADC1_COMMON->CCR = STM32_ADC_PRESC << 18;
  /* Regulator enabled and stabilized before calibration.*/
  adc_lld_vreg_on(ADC1);
  ADC1->CR |= ADC_CR_ADCAL;
  while (ADC1->CR & ADC_CR_ADCAL)
  ADC1->CR = 0;
  rccDisableADC1();
 * @brief   Configures and activates the ADC peripheral.
 * @notapi
void adc_lld_start(ADCDriver *adcp) {
  /* If in stopped state then enables the ADC and DMA clocks.*/
  if (adcp->state == ADC_STOP) {
    if (&ADCD1 == adcp) {
      adcp->dmastp = dmaStreamAllocI(STM32_ADC_ADC1_DMA_STREAM,
                                     STM32_ADC_ADC1_DMA_IRQ_PRIORITY,
                                     (stm32_dmaisr_t)adc_lld_serve_rx_interrupt,
                                     (void *)adcp);
      osalDbgAssert(adcp->dmastp != NULL, "unable to allocate stream");
      /* DMA setup.*/
      dmaStreamSetPeripheral(adcp->dmastp, &ADC1->DR);
      dmaSetRequestSource(adcp->dmastp, STM32_DMAMUX1_ADC1);
      /* Clock settings.*/
      adcp->adc->CFGR2 = STM32_ADC_ADC1_CKMODE;
#endif /* STM32_ADC_USE_ADC1 */
    /* Regulator enabled and stabilized.*/
 * @brief   Deactivates the ADC peripheral.
 * @notapi
void adc_lld_stop(ADCDriver *adcp) {
  /* If in ready state then disables the ADC clock and analog part.*/
  if (adcp->state == ADC_READY) {
    dmaStreamFreeI(adcp->dmastp);
    adcp->dmastp = NULL;
    /* Restoring CCR default.*/
    /* Regulator off.*/
    adcp->adc->CR = 0;
    if (&ADCD1 == adcp)
      rccDisableADC1();
 * @brief   Starts an ADC conversion.
 * @notapi
void adc_lld_start_conversion(ADCDriver *adcp) {
  uint32_t mode, cfgr1, cfgr2;
  const ADCConversionGroup *grpp = adcp->grpp;
  /* Starting the ADC enable procedure.*/
  adc_lld_start_enable_adc(adcp->adc);
  /* DMA setup.*/
  mode  = adcp->dmamode;
  cfgr1 = grpp->cfgr1 | ADC_CFGR1_DMAEN;
  cfgr2 = adcp->adc->CFGR2 & STM32_ADC_CKMODE_MASK;
  if (grpp->circular) {
    mode  |= STM32_DMA_CR_CIRC;
    cfgr1 |= ADC_CFGR1_DMACFG;
    if (adcp->depth > 1) {
      /* If circular buffer depth > 1, then the half transfer interrupt
         is enabled in order to allow streaming processing.*/
      mode |= STM32_DMA_CR_HTIE;
  dmaStreamSetMemory0(adcp->dmastp, adcp->samples);
  dmaStreamSetTransactionSize(adcp->dmastp, (uint32_t)grpp->num_channels *
                                            (uint32_t)adcp->depth);
  dmaStreamSetMode(adcp->dmastp, mode);
  dmaStreamEnable(adcp->dmastp);
  /* ADC setup, if it is defined a callback for the analog watch dog then it
     is enabled.*/
  adcp->adc->ISR      = adcp->adc->ISR;
  if (grpp->error_cb != NULL) {
    adcp->adc->IER    = ADC_IER_OVRIE | ADC_IER_AWD1IE
                                      | ADC_IER_AWD2IE
                                      | ADC_IER_AWD3IE;
    adcp->adc->TR1    = grpp->tr1;
    adcp->adc->TR2    = grpp->tr2;
    adcp->adc->TR3    = grpp->tr3;
    adcp->adc->AWD2CR = grpp->awd2cr;
    adcp->adc->AWD3CR = grpp->awd3cr;
  adcp->adc->SMPR   = grpp->smpr;
  adcp->adc->CHSELR = grpp->chselr;
  /* Ensuring that the ADC finished the enable procedure.*/
  adc_lld_wait_enable_adc(adcp->adc);
  /* ADC configuration and start.*/
  adcp->adc->CFGR1  = cfgr1;
  adcp->adc->CFGR2  = cfgr2 | grpp->cfgr2;
  /* ADC conversion start.*/
  adcp->adc->CR |= ADC_CR_ADSTART;
 * @brief   Stops an ongoing conversion.
 * @notapi
void adc_lld_stop_conversion(ADCDriver *adcp) {
  dmaStreamDisable(adcp->dmastp);
  adc_lld_stop_adc(adcp->adc);
 * @brief   ISR code.
 * @notapi
void adc_lld_serve_interrupt(ADCDriver *adcp) {
  uint32_t isr;
  isr = adcp->adc->ISR;
  adcp->adc->ISR = isr;
  /* It could be a spurious interrupt caused by overflows after DMA disabling,
     just ignore it in this case.*/
    adcerror_t emask = 0U;
    /* Note, an overflow may occur after the conversion ended before the driver
       is able to stop the ADC, this is why the state is checked too.*/
    if ((isr & ADC_ISR_OVR) && (adcp->state == ADC_ACTIVE)) {
      /* ADC overflow condition, this could happen only if the DMA is unable
         to read data fast enough.*/
      emask |= ADC_ERR_OVERFLOW;
    if (isr & ADC_ISR_AWD1) {
      /* Analog watchdog 1 error.*/
      emask |= ADC_ERR_AWD1;
    if (isr & ADC_ISR_AWD2) {
      /* Analog watchdog 2 error.*/
      emask |= ADC_ERR_AWD2;
    if (isr & ADC_ISR_AWD3) {
      /* Analog watchdog 3 error.*/
      emask |= ADC_ERR_AWD3;
    if (emask != 0U) {
      _adc_isr_error_code(adcp, emask);
 * @brief   Enables the VREFEN bit.
 * @details The VREFEN bit is required in order to sample the VREF channel.
 * @note    This is an STM32-only functionality.
 * @note    This function is meant to be called after @p adcStart().
 * @notapi
void adcSTM32EnableVREF(ADCDriver *adcp) {
  (void)adcp;
  ADC1_COMMON->CCR |= ADC_CCR_VREFEN;
 * @brief   Disables the VREFEN bit.
 * @notapi
void adcSTM32DisableVREF(ADCDriver *adcp) {
  (void)adcp;
  ADC1_COMMON->CCR &= ~ADC_CCR_VREFEN;
 * @brief   Enables the TSEN bit.
 * @details The TSEN bit is required in order to sample the internal
 *          temperature sensor and internal reference voltage.
 * @notapi
void adcSTM32EnableTS(ADCDriver *adcp) {
  (void)adcp;
  ADC1_COMMON->CCR |= ADC_CCR_TSEN;
 * @brief   Disables the TSEN bit.
 * @notapi
void adcSTM32DisableTS(ADCDriver *adcp) {
  (void)adcp;
  ADC1_COMMON->CCR &= ~ADC_CCR_TSEN;
#if defined(ADC_CCR_VBATEN) || defined(__DOXYGEN__)
 * @brief   Enables the VBATEN bit.
 * @details The VBATEN bit is required in order to sample the VBAT channel.
 * @notapi
void adcSTM32EnableVBAT(ADCDriver *adcp) {
  (void)adcp;
  ADC1_COMMON->CCR |= ADC_CCR_VBATEN;
 * @brief   Disables the VBATEN bit.
 * @notapi
void adcSTM32DisableVBAT(ADCDriver *adcp) {
  (void)adcp;
  ADC1_COMMON->CCR &= ~ADC_CCR_VBATEN;
#endif /* defined(ADC_CCR_VBATEN) */
#endif /* HAL_USE_ADC */
Posted: Tue Mar 15, 2022 4:25 pm
by dmene
The code hangs on:
Daniel
Posted: Tue Mar 15, 2022 4:43 pm
I think it is because ISR clearing before reaching that point, tomorrow I will be able to test it.
Posted: Wed Mar 16, 2022 11:40 am
Made more changes and tested the demo, it appears to work now. It has been committed on the repository.
Fixed as bug #1225.
