Simulator on Linux or Windows
gmb42
Re: Simulator on Linux or Windows
Post by gmb42 »
I fixed that issue with this change:
--- /home/Software/chibios/demos/Posix-GCC/main.c        2012-10-16 21:13:41.497321726 +0100
+++ main.c      2012-11-04 10:01:00.130219397 +0000
@@ -23,6 +23,7 @@
 #include "test.h"
 #include "shell.h"
 #include "chprintf.h"
+#include "stdio.h"
 #define SHELL_WA_SIZE       THD_WA_SIZE(4096)
 #define CONSOLE_WA_SIZE     THD_WA_SIZE(4096)
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Post by tfAteba »
I just read about this topic and look to trunk source files.
I see that there is a simulator board, and a WINDOWS demo on how to use it.
Is there a Linux demo version? Is the simulator is also supposed to work under Linux?
There was a Linux/MAC version up to 2.6.x, it has not been ported so far.
tfAteba
Post by tfAteba »
Thanks for this useful information.
russian
Has thanked: 16 times
Been thanked: 14 times
Post by russian »
Giovanni wrote:There was a Linux/MAC version up to 2.6.x, it has not been ported so far.
Google remembers about this thread and I assume that as of 2021 linux totally works just fine.
It does, it is what I use for testing.
JSStabl
Has thanked: 3 times
Been thanked: 2 times
Post by JSStabl »
Is there a explanation on how to run the demo? I tried compiling it with ubuntu and get a host of error messages :)
Edit: I was able to get the simulator running on a 32bit debian. Are there any places where we can see how the static and regression tests are run using the simulator?
On Ubuntu you need to add the 32bits development environment and it will work (I use it on Linux Mint).
The demo opens 2 ports, connects on those using telnet and you will get shells, from there you can execute tests.
Regressions tests are done by launching /test/rt/testbuild/go.sh. You need PC-Lint or you need to disable the lint pass in go.sh. This regression test runs RT under multiple configurations using the simulator and collects test and coverage data.
