Page 2 of 3
Re: Recursive mutex?
Posted: Fri Oct 19, 2012 12:42 pm
by Freddie Chopin
Sure you can do that, but all library functions from newlib don't call "malloc", but "_malloc_r", so if you really want to reimplement I'd suggest reimplementing that instead... Same goes for free()/_free_r(). Moreover - you don't reimplement calloc(), realloc() etc. this way, and these functions may be used somewhere (now, in the future) in newlib. The most generic solution is to NOT override malloc() but lock it with mechanism provided.
4\/3!!
Posted: Fri Oct 19, 2012 1:46 pm
by Prof. Dr. YoMan
You're right.
Giovanni posted a possible solution, this helps for me.
Posted: Wed Oct 24, 2012 9:46 pm
by Prof. Dr. YoMan
I guess this is the right way:
 * @file    newlib_locking.c
 * @brief   Recursive mutexes macros and structures. Newlib locking functions.
#include <reent.h>
#include "ch.h"
 * @brief   Recursive mutex structure.
typedef struct recursive_mutex_s {
  Mutex mutex;
  uint32_t count;
} recursive_mutex_t;
 * @brief   Static recursive mutex initializer.
 * @details Statically initialized recursive mutexes require no explicit initialization.
 * @param[in] name      the name of the recursive mutex variable
#define EXT_MUTEX_DECL(name) recursive_mutex_t name = { _MUTEX_DATA(name.mutex), 0 }
 * @brief   Locks the specified recursive mutex.
 * @param[in] rmp        pointer to the @p recursive_mutex_t structure
static void lock_recursive(recursive_mutex_t *rmp) {
  chSysLock();
  if (chThdSelf() == rmp->mutex.m_owner) {
    // Already owned. Recursion.
    rmp->count++;
  else {
    // Not owned. Lock.
    chMtxLockS(&rmp->mutex);
  chSysUnlock();
 * @brief   Unlocks the specified recursive mutex.
static void unlock_recursive(recursive_mutex_t *rmp) {
  chSysLock();
  if (rmp->count == 0) {
    // Last owned. Unlock.
    chMtxUnlockS();
  else {
    // Still in recursion.
    rmp->count--;
  chSysUnlock();
 * @brief   Recursive mutex for __malloc_lock.
static EXT_MUTEX_DECL(malloc_recursive_mutex);
 * @brief   Implements __malloc_lock from newlib.
 * @param[in] reent        pointer to the @p _reent structure
void __malloc_lock (struct _reent *reent) {
  (void)reent;
  lock_recursive(&malloc_recursive_mutex);
 * @brief   Implements __malloc_unlock from newlib.
void __malloc_unlock (struct _reent *reent) {
  (void)reent;
  unlock_recursive(&malloc_recursive_mutex);
 * @brief   Recursive mutex for __env_lock.
static EXT_MUTEX_DECL(env_recursive_mutex);
 * @brief   Implements __env_lock from newlib.
void __env_lock(struct _reent *reent) {
  (void)reent;
  lock_recursive(&env_recursive_mutex);
 * @brief   Implements __env_unlock from newlib.
void __env_unlock (struct _reent *reent) {
  (void)reent;
  unlock_recursive(&env_recursive_mutex);
 * @brief   Mutex for __tz_lock.
static MUTEX_DECL(tz_mutex);
void __tz_lock (void) {
  chMtxLock(&tz_mutex);
void __tz_unlock (void) {
  chMtxUnlock();
Correct?
These are all locks which are named in the newlibc documentation.
If I look into the libc.a in GNU-ARM-Embedded\arm-none-eabi\lib\armv7-m (this is the right one for cortex-m3 stm32f?) there are other _lock_... used.
_spf_lock_acquire/release, _sinit_lock_acquire/release, _fp_lock_all, ...
I want to get libc fully integrated. See also here: viewtopic.php?f=2&t=428 about _impure_ptr handling and don't want to miss a thing. What to do?
This newlib stuff looks weird for me. :)
Posted: Wed Oct 24, 2012 9:56 pm
Looks OK, but I would would modify the counter to be ==1 when the mutex is taken the first time and released in the transition to zero. This way count would mean exactly "count" times.
An implementation like this could be included, the problem is with condition variables, waiting on one of those would release the mutex only once even if it is taken N times, probably an assertion should explicitly prevent this scenario.
Posted: Wed Oct 24, 2012 10:11 pm
by Prof. Dr. YoMan
  chSysLock();
  if (chThdSelf() != rmp->mutex.m_owner) {
    // Not owned. Lock.
  rmp->count++;
  chSysUnlock();
  chSysLock();
  if (--rmp->count == 0) {
    chMtxUnlockS();
  chSysUnlock();
Like this, I guess. Feel free to include it.
I dont understand the problem with the condition variables. Just need to check what they are/do/dont do. :)
What about the other locks in the newlibc. Can you help out with informations how this works?
Posted: Wed Oct 24, 2012 10:15 pm
Yes, like that, there is also one less branch in the code. About condvars, those are a Posix mechanism, you can find a lot of documentation about those.
Posted: Fri Oct 26, 2012 10:00 pm
by Freddie Chopin
Prof. Dr. YoMan wrote:What about the other locks in the newlibc. Can you help out with informations how this works?
You need to recompile the whole library with proper sys/lock.h header in place - these cannot be easily overriden as malloc() locks, because in stub header all these locks are replaced (via #define) with "(void)0".
4\/3!!
Posted: Fri Oct 26, 2012 10:08 pm
by Prof. Dr. YoMan
Ok, but what about the _spf_lock_acquire/release, _sinit_lock_acquire/release, _fp_lock_all, ... which I find in the libc.a and which seem to get used by sprinft and other stuff?
Posted: Sat Oct 27, 2012 7:57 am
by Freddie Chopin
You can try overriding that, which will probably work, but you cannot override things like initializers - this will have to be done manually.
But... These are just some function-wrappers for a really small subset of newlib's libc locks - check newlib's source and search for strings like "__lock_acquire" or other things from lock.h - these are used too, but the stub replaces them with "(void)0", so these are not even called. That's why to have a proper and complete mechanism, you need to recompile the lib...
4\/3!!
Posted: Sat Oct 27, 2012 2:03 pm
by Prof. Dr. YoMan
And even if I do I get the problem with condvars as Giovanni describes above if I extend the mutexes to be recursive. ...
Not nice. For me a fully working libc is needed. Same for libstdc++ even if it is a memory hog. Attaching memory is cheap and if it brings down development time and code readability up I want to use working blocks.
