USB problem with Configuration Descriptor
Re: USB problem with Configuration Descriptor
I'll give a try, probably in the weekend.
Spider
Post by Spider »
And I can't send from FW any descriptor more than 0xFF bytes :(
I'll try to verify this as soon as possible, I am a bit overloaded of late.
Spider
Post by Spider »
I add to my descriptor "Interface Association Descriptor" with USB Microphone Interfaces and Endpoint, and this way or resolving problem not work. I set descriptor to 0x100 bytes and it transmit to driver but with out 1 last byte (problem with 0xFF length). Descriptor transmitted correctly (several last bytes only for rounding) but device not work, I think because length defined 0x100, but transfered 0xFF. I don't know how to explain it :) In result device detected as not work and not configured, but SET_CONFIGURATION setup packet sent to device :)
Spider
Post by Spider »
Any news?
Not yet, I hope to be able to give it a try next week.
Spider
Post by Spider »
I still waiting for help :)
I am trying your test application after adapting it to a F3-Discovery, the host (WinXP) enumerates it but the installation does not finish, the device is marked as USB Composite Device with an error (This device cannot start. (Code 10)).
Is this supposed to happen?
Weird, if I remove the 20 zero bytes from the descriptor and change the length to 0x6D then it works perfectly and all the devices are recognized.
Isn't this the expected result?
Spider
Post by Spider »
Hello!
With Happy New Year!
In my case I have STM32F103 and next situation:
If I write descriptor length 0x81 with padding bytes, all work.
If I write descriptor length 0x6D w/o padding bytes - not work, and device not recognized.
What I do wrong?
I haven't HW USB Analyzer, but I attached logs from USB Lyzer. Look at them.
USB Composite.rar
(6.46 KiB) Downloaded 408 times
