Page 2 of 2
Re: Floating point issue on Raspberry PI
Posted: Sat Dec 01, 2012 5:04 pm
by robu
It's the same effect I'm getting just 0.000
Regards,
Robert
Posted: Sat Dec 01, 2012 7:34 pm
by gmb42
Are you sure the object file for chprintf got recompiled? Did you "make clean"? I tripped over that when I was trying to get fp output last week.
Posted: Sat Dec 01, 2012 9:56 pm
by robu
If I don't set the CHPRINTF_USE_FLOAT flag than insted of the number it will print out only a f
Posted: Sat Dec 01, 2012 10:08 pm
by gmb42
OK, I'm out of advice now, it works for me on an STM32F4.
Posted: Sat Dec 01, 2012 10:11 pm
by robu
Thanks for your help.
Posted: Sun Dec 02, 2012 9:10 am
by mabl
Wasn't there once an issue with varargs and floating point? Which also never got solved and the "toolchain" got the blame? I'd wager this is the same case.
What is the status of the raspberry Pi Port? I guess it needs a recommended toolchain and working debugging. OpenOCD should support it, right?
Posted: Mon Dec 03, 2012 11:23 am
by Badger
mabl wrote:Wasn't there once an issue with varargs and floating point? Which also never got solved and the "toolchain" got the blame? I'd wager this is the same case
I've experienced the same issues with STM32. I never found the time to get to the bottom of it, I just printed a scaled integer instead. There's some more info
here.
Posted: Mon Dec 03, 2012 2:54 pm
by robu
Thanks for the help, I will give a try.
Posted: Wed Dec 19, 2012 9:02 pm
by robu
Finally I figure it out the problem.
There was the stack initialization problem, I added
to the vector.s and now it is working
Robert
